Results 1 to 5 of 5
Thread: Just replaced windshield washer fill tube.... need tube clips
    Jun 2005
    NJ
    2000 540i
    Hi all,
    I just replaced my filler tube for my washer reservoir on my '03 E39 540. The problem i have is that the tube is held tight to the frame in the wheel well with two circular clips that go around the tube, and then have 2 small "nubs" that come together and are pushed into a small hole. My two clips have broken, and I cannot find them anywhere on any parts explosions. Does anyone happen to know what these clips are, and what the part number is?
    Thanks much!
    Mike De Cou
    Jun 2005
    NJ
    2000 540i
    And... I found it. 61668229751
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    And..... I moved it from DIY to the general E39 forum. E39 DIY is for fixes, questions post in the general forum
    Los Gatos CA
    1987 325is, e34, Z3, e39
    A suggestion: reinforce the exposed area of the tube with large (1.5") heat shrink tubing. That will provide some protection from gravel and abrasion, and costs much less than the $50 for a new tube.
    I haven't found a gentle way to remove the old tube from the tank. Collapsing the end of the old tube seems to be the best approach, rather than risking damage to the tank.
    Jun 2005
    NJ
    2000 540i
    Thanks for the suggestion. I too decided to colapse the old tube. I didnt want to try ripping it out of the tank. I will give the heat shrink a try, as I dont feel like doing this again.
  1. DIY for windshield washer reservoir/tubing replacement?
    By nsheffer in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-25-2020, 06:18 AM
  2. Replies: 0
    Last Post: 04-01-2012, 08:41 PM
  3. Replace Windshield Washer Sprayer / Nozzle
    By EuphoriousCntrl in forum 1991 - 1999 (E36)
    Last Post: 07-02-2010, 07:35 PM
  4. Replacement windshield washer nozzles?
    By Donovanj in forum 1992 - 1999 M3 (E36)
    Last Post: 04-12-2006, 03:04 PM
  5. windshield washer tube and harness
    By bdub in forum 1992 - 1999 M3 (E36)
    Last Post: 02-01-2004, 05:28 PM
