Results 1 to 6 of 6
Thread: Rear subframe mounts botched install
    Nov 2017
    Brunswick MD
    1995 540i
    I replaced the rear subframe mounts on my E34 but screwed up and used oil in place of soap and water when reinstalling the mounts. As a result, the subframe has shifted upwards roughly 1/4 of an inch on the mounts towards the body.
    No clunks and the car seems to drive fine. Is this a major safety issue or not a large deal?
    Dec 2017
    Chicago Illinois
    2003.5 E46 M3, 1992 e34
    The bracket that bolts into bottom of bushing, did you torque it down while car was on ground or in air? You supposed to tighten it when cars on ground apparently. Possibly if you retighten it could push bushing up?
    Nov 2017
    Brunswick MD
    1995 540i
    Quote Originally Posted by jmile46 View Post
    Bushing is tight against the body. I torqued it with it in the air to 110ft lbs, but as soon as there is any weight on the subframe it works it’s way up.
    I’ll probably drive it for a bit and see if it clunks around; I just don’t want the subframe to damage the unibody.
    Hamburg, NY USA
    e23, e32, e34, e39
    I think the easiest way to fix this would be to get the sub frame back down drill a hole or two in the sub frame and screw it to the bushings metal sleeve.
    Aug 2009
    Richmond, VA
    1999 Eclipse GSX
    Quote Originally Posted by m735is View Post
    I think the easiest way to fix this would be to set the car on fire.
    Fixed
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    I would remove the mounts (they don't look very attached to their positions; should be easy), clean them up as best as I could with soap and water, to remove as much oil contamination as possible, maybe even soak them in soap, and reinstall. They see considerable vertical force and I don't expect screws to last.
  1. Rear subframe mount installation
    By custom32 in forum 1983 - 1991 (E30)
    Last Post: 07-11-2005, 05:18 PM
  2. Rear Subframe Mounts
    By ImageDynamicsM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-22-2003, 02:15 AM
  3. Replacing rear subframe mounts....?
    By bmwman91 in forum 1983 - 1991 (E30)
    Last Post: 10-17-2002, 07:27 PM
  4. Replacing rear subframe mounts on an E30?
    By bmwman91 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-16-2002, 10:38 PM
  5. Replacing rear subframe mounts on an E30?
    By bmwman91 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-04-2002, 03:01 PM
