Results 1 to 11 of 11
Thread: Dropped small bolt for lower chain tensioner into sump
    Mar 2015
    Severn MD
    98 328i 10 328i X wagon
    HELP! I think I dropped the small bolt for the lower chain tensioner into the sump. I know I dropped it and thought I saw it go down the floor but cannot find it anywhere. I know all the videos say to put rags in there to prevent this. Well I just forgot to do it. I know that you need to drop the entire front suspension to drop the sump. What a huge PIA. Anyone have any other ideas? If I finish putting the vanos together and then rotate the engine by hand I guess I would know if the bolt got caught in the timing chain. If not I guess it is sitting in the bottom of the sump. I can't really see down in there to tell if it is actually there. Anyone find an easy way out of this kind of situation?
    Apr 2015
    Tennessee
    1998 BMW 328i
    Is there oil in the sump? You could try pulling the dipstick or drain plug and going fishing with a magnet
    Mar 2015
    Severn MD
    Anybody ever use one of those boroscopes that you can put on your phone. If I could look down in there and know it was there it might make sense for me to drop the suspension and oil pan. Anyone ever try this?
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by sharadn View Post
    I have one, but haven't used it for sump inspection.
    I would try with one of those telescopic magnet pick-up tools. Has saved my life a few times.
    IG:
    Mar 2015
    Severn MD
    I bought one of these:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    It came today and is a bit difficult to actual know what you are looking at but I don't see anything down in there that looks like it has threads. Maybe it disappeared into a garage cranny and will come out in six months after I drop the subframe and pan.
    Mar 2015
    Severn MD
    Sold the E36 as a project and bought an E46 M3. Too much work in too small of a garage.
    The Netherlands
    Like that. Drop bolt in sump, buy new car.
    IG:
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    What about when you drop a bolt in the S54? If an e36 is too much work you may be in for a ride with an S54.
    If the bolt dropped down the front timing case then a magnet should easily pull it back up, also if it totally made it to the sump it is way to big to go through the pump pick up screen and not nearly enough to block flow to the pump, the only risk is to make sure it isn't in your timing chain or guides and then get a new bolt and forget about it All you would need to do is look down the front timing case. Too late now, I suspect there is more to the story.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by jc43089 View Post
    If you drop a bolt in the pan of the S54 you can retrieve it when you put new rod bearing in as PM.
    Gave away my BMWs, driving a VW and an Audi now.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Quote Originally Posted by jmo69 View Post
    Exactly my point lol.
    Mar 2015
    Severn MD
    Not much more to the story than I wanted a M3 and I bought one. I guess going from an e36 328i to e46 M3 is the right direction. I am not twenty anymore and I have to decide where is the best place for me to use my energy. I would much rather spend my time and work on the M3 than the 328. Working on one or the other is OK but not both. I do have a life and wife outside of the garage.
    You know what JC43089: you are exactly correct: I am sure that the S54 will be quite a ride! And thanks for your great input!
  1. Lower chain tensioner
    By mtnsmith in forum 1992 - 1999 M3 (E36)
    Last Post: 09-04-2009, 02:05 PM
  2. Replies: 5
    Last Post: 09-05-2006, 12:38 AM
  3. FS: used 2K miles Lower Chain Tensioner
    By M3Jokster in forum BMW Parts For Sale
    Last Post: 12-02-2005, 01:08 PM
  4. Lower Chain Tensioner - help
    By craaaazzy in forum 1992 - 1999 M3 (E36)
    Last Post: 05-18-2005, 10:45 PM
  5. Lower chain tensioner installed in a 97
    By eclou in forum 1992 - 1999 M3 (E36)
    Last Post: 03-16-2003, 09:37 AM
