Results 1 to 9 of 9
Thread: suspension arms e46 in e36
    Sep 2018
    Spain
    318ti
    Hi all! possibly there has been a lot of talk about the subject but I can not find anything I'm sorry
    I would like to know if it is necessary to make any modifications to put the suspension arms of an e46 in an e36 compact or would it be plug and play? I imagine that we should also buy the silentblocks of an e46
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    I think the e46 front control arms are guite a bit longer, and more forward. You would need some unsafe severe shimming at the lower strut mounts on top of camber plates if not a chop and weld of the actual strut mount domes. But, I may be wrong.
    Sep 2018
    Spain
    318ti
    I have camber plates that I think is necessary to be able to put the e46 arms and from the silentblocks I have found this:
    https://www.strongflex.eu/en/bmw-e30...553504002.html
    inside they have a hexagonal shape like the arms of e46 but the outside measures what is necessary to install it in the blocks of the e36
    but if I have to cut and weld it is not as simple as buying some pieces to make everything fit,
    Nov 2013
    Oneida, NY
    No, I think your right. It's for drifting and not speed. Its for a better turning lock angle,. I remember seeing this now. You should be good. That bushing is just for the e46 arms with that particular shaped end. See what you have on your arm and order to fit.
    Apr 2015
    Tennessee
    1998 BMW 328i
    In order to run e46 control arms, you will need to purchase a bushing conversion kit with the hexagonal insert. I think condor speedshop sells them but they are about $200. I believe you will also need to use e90 tie rods to account for the increased arm length. And you may also need to modify the knuckle by cutting and welding where the tie rods and control arm balljoints fasten.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by XnWarden View Post
    Man, I'd stay away from cutting and welding something like the knuckle.
    I have a friend who did this and swapped to an E46 knuckle / front strut. And yes, you will need the right outer tie rod (from an E46). And you'll also have to use the E46 brakes, since that's what bolts up. So it's a bit more involved parts wise, but it all bolts up. Except...
    It's really wide (which is the point, obviously), and you will also have to cut your fenders / add flares.
    Nov 2013
    Oneida, NY
    E36 and e46 brakes are interchangeable as long as rotors match the caliper.
    Jul 2011
    Austin, TX
    Quote Originally Posted by spyderg0d View Post
    True. My buddy went to an E46 M3 arm (and everything else) up front. No point in going to that much time, effort, and money and then keeping e36 brakes. Though if you're drifting and not racing it doesn't matter so much.
    Sep 2018
    Spain
    318ti
    Quote Originally Posted by blckstrm View Post
    I think the same thing, avoid always cutting and welding because you have a piece that does not give much improvement either.
    Although I'm really interested in putting it because it gives a little more angle of rotation and a little separation on the wheels, on the side of the car's fins I do not worry because I do not think that with the angle of camber to the maximum go to brush in the car
  1. suspension from E46 to E36
    By 8ish in forum 1991 - 1999 (E36)
    Last Post: 08-19-2014, 06:15 AM
  2. E36 Ground Control lower control arms NEW! fit E36/E46
    By ghambino in forum Race Cars & Track Parts
    Last Post: 06-26-2012, 01:01 PM
  3. E36 (1) Lemforder Rear Control Arm Ball Joint E36 & E46
    By graaf35 in forum Suspensions, Springs & Shocks
    Last Post: 03-07-2012, 05:17 PM
  4. E36 FS - UUC Urethane Rear Trailing Arm Bushings RTAB E36/E46 == NEW ==== $40 Shipped
    By fritzintn in forum Suspensions, Springs & Shocks
    Last Post: 09-30-2010, 10:41 AM
  5. Adjustable Suspension Arm's for e36 m3
    By sportcarm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-11-2005, 01:17 PM
