Results 1 to 3 of 3
Thread: E39 Help Needed
    Oct 2018
    Triangle, VA
    2002 525i
    E39 Help Needed
    I had my 525i motor swapped to a 530i recently. My brother did the swap. He said he did not need to switch the ECU because the car started with original still in place.
    The problem now is the ECU says OFF in my scan tool for everything except Misfire,MAF, etc. All other secondary systems is not available.
    What can I do to get my car emissions ready? I live in Northern Virginia and cannot get tag decals until emissions is clear.
    Thanks for any info you can give.
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    Okay. this should have worked fine. What scan tool are you using ? Does it start and run? If you are not able to read other modules, It sounds a little like an electrical issue & possibly a bad ground. You or your brother need to re-check all connections and ground connections that were disturbed as part of the swap. I left the ECU (DME) ground wire off and wasn't able to connect to the DME..then again the car would not start.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Have you done a couple official "Drive Cycles"? You know you have to drive it for a while / miles and to some degree multiple starts to get readiness?
    Being sure you did a drive cycle of course.
    There's an order to the "Monitors" being ready and they are interdependent, so, the last things to go will be Cats for instance, and if the O2s aren't ready you'll never get the cats.. you won't get the O2's if you don't get XYZ first etc. etc.
    So you have to look at the things that aren't ready and work them through one by one....
    Oh and - every time you clear codes you're resetting the drive cycle / readiness, you actually just may be fanatically clicking "clear codes clear codes" with your dopey little OBD reader, and constantly resetting all the readiness timers... which might just be the only problem...
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  1. E39 Help needed w/ "Fat man mode" on the key memory...
    By geargrinder in forum Diagnostic Software
    Last Post: 11-25-2012, 10:04 AM
  2. E39 Help needed...
    By coopersguy in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-15-2011, 08:21 AM
  3. E39 wheel/tire help needed
    By C5driver in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-22-2004, 11:00 AM
  4. E39 528i Oil Change~Help needed~
    By keoaloha in forum 1996 - 2003 (E39)
    Last Post: 08-14-2003, 08:36 PM
  5. Jacking up E39 & jackstands, help needed..
    By Lscman in forum 1996 - 2003 (E39)
    Last Post: 08-14-2003, 02:51 PM
