I bought a spare tire from Bav. auto and threw it in the trunk. Since there is no space for it its always in the way when using the trunk. Before I custom make something I wanted to see if anyone else has already done this? It would be in the shape of the floor with legs that hold it up 1/4" taller than the spare tire. This way I would have a removable panel that I can use as the new trunk floor.
Mike
2010 328xi, 2004 M3, 86 twin turbo GN
Is there no spare on the wagon models?
Have you looked under the rear floor cover? There is no room for a spare, and no cavity to hold it. There is no reason to make a cover because the tire will essentially be sitting above the floor anyway. I believe that Pelican parts makes a cover with anchors to tie it down. I have an 08 wagon and I carry a plug kit and a 12V air pump, so i figure I'm set unless something totally tears up a tire. Those items fit in the small cargo cavity under the rear floor cover.
