Results 1 to 9 of 9
Thread: Temp sensor values for this picture
    Jan 2012
    Vancouver, BC Canada
    1985 Mercedes 300SD
    Hey all, I'm working on chasing down my rough idle on my 733i and I found this great picture of all the temp sensors and what they're for. I was hoping that someone here could fill me in as to what they should read if they are still good. Could anyone provide that info so I can check them all?
    thanks folks
    1983 BMW 733i My current project (or at least one of them)
    2003 Volvo V70 5 Speed Current Daily Driver
    1993 300TE 4Matic Project wagon -sold
    1997 E290 Turbo Diesel Wagon -traded for above, an amazingly comfortable car to drive, great drivetrain, but the rust, oh my god the rust
    1992 BMW 525i -traded in
    1990 Silver 300TE -Sold Loved the wagon, hated the M103
    1985 Grey 380SE Diesel Conversion, 2.47 rear end, ABS -Sold, really should have kept this one
    1979 Silver 300D "The Silver Slug" -Sold
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Well...it depends! On coolant temp.
    Temp sensor with two prongs just runs to gauge cluster. The one to the Motronic is an NTC, I would assume the others follow suit. Make sure now hacker put in a resistor in the harness. The thermotime is for cold starts only. Not familiar enough with the other that is for idle control unit, sorry.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    May 2013
    Killingworth, CT
    '84 733i, 01 X5 00 750iL
    I have an excellent running 1984 733 that idles well. I can check these tomorrow at ambient temp if you want
    Steve H.
    Quadratechtown, PA
    5, 7, 4x4
    Most of that information is in the Bentley E28 5-series manual. A valuable addition to the repair documentation for the E23.
    Jan 2012
    1985 Mercedes 300SD
    @bobdospecial
    I'd appreciate that, thanks.
    @8991xj
    I know, I've been trying to avoid a lot of further investment until I see if I can get it to run better.
    Quadratechtown, PA
    5, 7, 4x4
    Maybe a search of mye28.com will reveal the numbers for you. I'm sure they have been posted in a few threads, maybe more than one sensor per thread but searching to find them might be a bit difficult. But give it a try as we await the answers.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Pester me and I will dig out my Bentley book for you. Main CTS to the ECU starts high, like in the 1000s and drops to the 100 area hot.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Mar 2013
    USA
    E21/early e23/e34
    This is want you want- same as my '79- Your's may be the shorter sensor (bottom protruding into housing) but this will work.
    https://www.ebay.com/itm/BMW-E23-E24...Yk~:rk:20:pf:0
    Dec 2019
    Ontario
    733i
    Hey.. Did you ever get any resistance info on the coolant temp for idle sensor? The manual I have is useless for this.
  1. Temp sensor to ECU test values
    By bimas in forum 1976 - 1989 (E24)
    Last Post: 03-23-2016, 01:11 AM
  2. Replies: 6
    Last Post: 02-07-2015, 04:07 AM
  3. 2000 e46 temp sensor ohm value?
    By scottysr in forum 1999 - 2006 (E46)
    Last Post: 06-17-2011, 02:20 AM
  4. Interior Temp Sensor - Resistance vs. Temp Values
    By Agent Crash in forum 1991 - 1999 (E36)
    Last Post: 12-22-2009, 10:45 AM
  5. Need help finding Intake Air Temp. Sensor
    By dbruce in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2001, 04:52 AM
