Results 1 to 15 of 15
Thread: A few floor pan questions,
    Aug 2012
    Central, MD
    1995 M3
    Considering fabbing up a driver side floor pan (after removal of carpet), E36.
    - What thickness of aluminum diamond plate is commonly used?
    - Anyone used perforated or expanded aluminum panels?
    May 2015
    Easton, PA
    1996 BMW 328is
    Is this because of rust, to level the floor, or aesthetics? I replaced a rotted floor and tossed the carpet...I had originally planned on fabbing or purchasing a diamond plate floor to make it flat...but then found that I didn't mind driving it as is. Didn't impact my ability to modulate throttle or heel/toe at all...so I'd say if you're after function over form, give it a shot as is first and see if you like it.
    (I know this wasn't your question...just my experience I thought I'd share in case you were doing it because 'they' say you need to)
    Aug 2012
    Central, MD
    1995 M3
    Thanks, good idea actually. It's not rust, just pulling the nasty carpet (cause, mostly track car). I bought some 5053 plate AL, 0.09" thick. Always good to have some of that stuff around anyway if I decide not to use it.
    Aug 2012
    Central, MD
    1995 M3
    How do these floor pans attach to the car? I can see easy attachment at the rear of the panel, where else?
    Aug 2017
    Antwerp
    E36 328i track car
    I used aluminuim diamond plate (1mm thickness and ribs 2mm), bent it so it would fit under the pedals, bent a lip op the left side for attachement to the side of the car and riveted it in place, the right side just rested on the floor.
    I dont have photo's of mine but used these photo's as inspiration
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    I had one sheet of 0.125 aluminum diamond, measuring 12"x36." It was bought for something else that never came to pass.
    That was plenty of material to do both sides of the car, and it has been plenty thick.
    I didn't bother covering anything except the flat area where I put my feet. The forward edge butts up against the accelerator pedal hinge, and for width I cut it so it stretched from the tunnel to the footrest and butted up tight on each of them.
    I bolted the aluminum directly to the floorpan on the tunnel side. Used a piece of steel square tube about 10 inches long as a spacer between the aluminum and the floor on the footrest/outer side, and bolted straight through that down to the floorpan. I can't remember, the tube was probably 1" square tube but it may have been a little larger.
    It has been very sturdy for a full season. I would do it the same way again.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
    Aug 2012
    Central, MD
    1995 M3
    Thanks, I appreciate the details!
    Aug 2009
    Metro DC
    Quote Originally Posted by aeronaut View Post
    I will try to remember to snap a photo and post it up, but I am notoriously slow about this kind of thing.
    Aug 2012
    Central, MD
    1995 M3
    Gotta install a few more rivnuts, some anti-slip tape, and some protection around the sharp edges near wires. But mostly done.
    May 2015
    Easton, PA
    1996 BMW 328is
    Nicely done!
    Aug 2012
    Central, MD
    1995 M3
    Thanks! I'm not sure a fiber reinforced panel wouldn't be better here. Would insulate against heat. But, here's my final install.
    Aug 2009
    Metro DC
    WAAAY nicer than mine!
    Aug 2012
    Central, MD
    1995 M3
    Looks 100% functional! I actually like the fact that yours is 1/2 length. I plan to cut some 'speed holes' in mine.
    Pittsburgh, PA
    E36 M3 / 2.0T WRX
    Not sure how much money you have allocated to buying the raw materials to make this plus the cost of your time involved.
    But for me, these pre-made floor pans seem like a no-brainer at $200 for both LH/RH.
    http://mkahmotorsports.com/e36-diamo...r-single-side/
    Aug 2012
    Central, MD
    1995 M3
    Thanks, I've seen those. I like mine better.
    No doubt, if you count your time, you rarely come out ahead on a custom fabrication vs production. But I'm in it for the fun.
  1. floor pan question
    By 1988Bmw325iconv in forum 1983 - 1991 (E30)
    Last Post: 09-19-2015, 03:45 AM
  2. Floor pan questions
    By maikell77 in forum 1983 - 1991 (E30)
    Last Post: 12-16-2009, 03:06 PM
  3. Rear floor pan repair question?
    By E36 328is in forum 1976 - 1989 (E24)
    Last Post: 02-03-2009, 07:10 PM
  4. A few new owner questions...
    By truth in forum 2001 - 2006 M3 (E46)
    Last Post: 07-14-2003, 09:50 PM
  5. Help needed: a few quick E38 questions
    By CMT in forum 1995 - 2001 (E38)
    Last Post: 09-04-2002, 03:46 PM
