Results 1 to 6 of 6
Thread: Where to install O2 Sensor?
    May 2018
    Rhode Island
    1986 BMW 325e
    My 86 325e currently doesn't have an O2 sensor, and the exhaust manifold is missing the hole to where the O2 sensor screws in. I recently got a new catalytic converter and muffler but those are also missing any mounting holes for the sensor. Where can I install it?
    Regina, Sask, Canada
    82 320i 89 325i
    screws into the exhaust downpipe just past the manifold. if one isn't present you will have to add a bung to screw it in. has the exhaust on the car been replaced in the past ?
    Oct 2003
    Seattle
    99 M3
    I believe the single O2 sensor is typically found just forward of the catalytic converter or where the factory ‘cat’ was. Needs to be in the merged exhaust stream.
    May 2018
    Rhode Island
    1986 BMW 325e
    No, this is a new catalytic converter. It's a really cheap Bosal Catalytic Converter(I'm on a tight budget), what exactly is a "bung" and how can I add that to my cat?
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    its the threaded thing the o2 screws into. you have to drill a hole and weld the bung over it so the o2 sensor is in the stream. I have never personally done it but always have a shop do it because I don't have a bit larger enough for the hole
    No e30s again.
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    Here is a picture from Realoem that shows where the O2 sensor goes.
    No. Description Supp. Qty From Up To Part Number Price Notes
    01 Exhaust pipe, catalytic converter 1 09/1987 11761711822 $1866.23
    02 Hex nut M10 6 18301737774 $1.65
    03 Gasket Asbestos Free 2 11761711717 $18.37
    04 Bracket exhaust pipe 1 09/1987 18301716424 $27.70
    05 Hex bolt M8X20-ZNS 2 07119901120 $0.60 ENDED
    05 Hex bolt M8X20-ZNNIV SI 2 07119903039
    06 Washer A8,4 2 33311108205 $0.16
    07 Hex bolt with washer M8X25-SB-Z1 1 07119915171 ENDED
    12 Oxygen sensor 3-POL/520MM 1 11781286638 $267.20 ENDED
    12 Oxygen sensor L=1790MM 1 11781716156 $218.18
    13 Cable LAMBDASONDE 1 12511288223 $19.41
    14 Bracket 1 12521289423 $2.41
    15 Holder D = 13MM 1 61131371074 $2.52
    16 Protection plate 1 11781710590 $33.49 ENDED, +core
    Notes
    • ENDED = the part has been discontinued (no longer available).
    • +core = plus core charge (possibility of a return of the old part)
    Sponsored links
  1. Smoke coming from newly installed O2 sensor
    By LJSE34 in forum 1983 - 1991 (E30)
    Last Post: 03-19-2011, 05:20 PM
  2. Good to install o2 sensors now or wait?
    By Lastb0isct in forum 1988 - 1996 (E34)
    Last Post: 01-05-2007, 02:16 PM
  3. Wideband O2 sensor....where to install O2 sensor
    By M3Jokster in forum Forced Induction
    Last Post: 08-26-2005, 02:32 AM
  4. How easy is it to remove/install o2 sensor on my 93
    By Bimmer325 in forum 1991 - 1999 (E36)
    Last Post: 02-02-2004, 07:52 AM
  5. any tips on installing O2 sensor in 94 325?
    By madsedan in forum 1991 - 1999 (E36)
    Last Post: 03-11-2001, 10:17 PM
