Results 1 to 10 of 10
Thread: Transmission Whining Noise (Not the throwout bearing)
    Jan 2018
    Luxembourg
    bmw e36 320i
    Hello,
    I have a problem with my e36 320i M52b20, so ever since I bought the car, there is a whining noise coming from the transmission when the clutch is engadged. However when the clutch pedal is pressed to the floor the whining stops.
    It is not the throw-out bearing because I replaced it and the noise persisted. My guess is the pilotbearing as it is the only one I can think of.
    Any other suggestions on what might be causing this noise?
    Bothell, WA
    ummm...
    Pilot bearing. Roommate has a bad pilot bearing. It sounds like it has a whimsy supercharger
    11/85 635csi auto
    Jan 2018
    Luxembourg
    bmw e36 320i
    yep sounds exactly like that. do you think its worth spending another 8 hours replacing the bearing? Should I replace it or can I drive like this for another month or so?
    Bothell, WA
    ummm...
    My roommate been driving it like that for a while now. Probably 5 months. He has a "loud stereo in his bmw"(whoopty f-ing doo), so he really doesn't hear it. He's not a bmw enthusiast, just likes to own one.
    11/85 635csi auto
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    The only time the pilot bearing actually does work is when the engine is running, the transmission is in gear and the clutch pedal is depressed (clutch disengaged). This means the transmission input shaft is stationary and the pilot is now working between the input shaft and the crankshaft/flywheel. If the engine is running, clutch disengaged and transmission in neutral the the bearing MAY turn just by the slipping motion of the clutch plate but no real load on the bearing. If you're traveling down the road in gear then the bearing is NOT turning (no load ). You never mentioned testing in or out of gear but it sounds more like a worn input shaft bearing.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
    Jan 2018
    Luxembourg
    bmw e36 320i
    Quote Originally Posted by tjm3 View Post
    Uhmm I think you just contradicted yourself, first you said that the pilot is working when the transmission is in gear with clutch depressed, then you say when I drive down the road the pilot is not spinning? but the two situations are one and the same no?
    To be clear, the noise occurs as soon as I let the foot of the clutch pedal, doesn't matter if I am in neutral or in gear and driving.
    Quote Originally Posted by 6inarow View Post
    Lol thats also a solution, Ill just buy a better stereo instead of a pilot.
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    No contradiction.
    Any time the clutch is engaged (pedal up, no feet) the crankshaft, flywheel, clutch, pressure plate and input shaft are spinning at engine RPM and the pilot bearing is not in play (other than just a locator) and there is no movement at the pilot bearing. The pilot bearing only works when the engine is running, the clutch is disengaged and the transmission is in gear, moving or not.
    See ya later,
    tony
    Jan 2018
    Luxembourg
    bmw e36 320i
    No contradiction.
    Ooh alright sorry I missunderstood you there, I get confused with the words engaged disengaged bla bla.
    Sooo it is the input shaft bearing then, any way of fixing it or at least stoping it from whining? Or should I consider buying a new transmission?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    A very simple decison: if the part in question is available as single part with a part number, you can order it and replace it, not a complete transmission, use your VIN and find the p/n http://www.realoem.com/bmw/enUS/select
    Get a Bentley Repair Manual for the E36, if you want to DIY.
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Quote Originally Posted by Denjeesi View Post
    This is not a 100% diagnosis, only a more likely scenario assuming there's no additional problems. Someone with driveline and transmission experience needs to listen to the noises while actually in the car.
    I'd be the first to say that RDP (Remote Diagnostical Procedure) doesn't always work.
    See ya later,
    tony
  1. Replies: 21
    Last Post: 06-11-2014, 10:27 AM
  2. 3.0i makes whining noise, not supercharged
    By Silberwald in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-18-2012, 08:40 PM
  3. Replies: 8
    Last Post: 09-19-2011, 10:31 PM
  4. Transmission rebuild or just a throwout bearing replacement?
    By shotcaller989 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-27-2008, 12:44 AM
  5. Blown Converter? Loud transmission whining noise
    By jdturbocharging in forum 1991 - 1999 (E36)
    Last Post: 11-14-2007, 07:18 PM
