Results 1 to 7 of 7
Thread: cilinder 6 misfire, reset ecu, it works
    Oct 2018
    Almaty, Kazakhstan
    2002 BMW E39 Sedan
    Hello dear friends
    car model: 2002 BMW e39 sedan M54.
    problem: Have problem with cylinder 6, it is misfiring or ecu turns it off. Cylinder misfires occasionally on warm engine especialy on cold. Resetting it with my OBDII when engine is running, it is starts to work again. Have replaced the coils and spark plugs no result problem appears again.
    Please help!
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    I can't tell you what your problem is, but just turning the engine off and back on will allow the cylinder to run, that is until a misfire is sensed again.
    Oct 2018
    Almaty, Kazakhstan
    2002 BMW E39 Sedan
    Thank you for respond. but i did not understand what you mean with: "turn engine off and turn it on again until engine misfire sense again"?
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    I'd pull the spark plug and take a look. (Is there oil around the plug while it's still in? Once removed, does the plug look OK, or is it dark from carbon fouling? Or is it wet with oil?)
    If the plug looks ok I'd swap that coil with another one, to see if you get a code for a different cylinder. (I understand that you changed the coil, but it's worth testing it while you're replacing the plug.)
    Sonoma Whine Country
    E12, E12, E36, E39
    There's an assortment of possible problems of course, but I too have had a similar problem, although if I drive it off at least at a moderate pace it goes away and doesn't do the fuel shutoff.
    https://www.bimmerforums.com/forum/s...-start-P-codes
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Turning the car off resets the misfire condition on the car's computer. When you turn car back on, the cylinder that the computer shut down is allowed to run until the computer senses a misfire condition. At this point, the computer will shut the cylinder down again. Now the check engine light will remain on until senses a 'no misfire' condition for a certain amount, that is only known to the computer. You can do this as many times as you want.
    Oct 2018
    Roseburg, Oregon
    2001 BMW 530i Touring
    That is a very similar symptom to when I had an exhaust valve burn in my M54. Except mine wasn't just a slight misfire, it was a full on power-killing miss. I was on my way home, climbing the Siskyou Mountains in the snow at 11:00 PM. Every time the light came on, I would reset it and the car would run slightly better until it came back on.
    Checking compression and leakdown on that cylinder might be a good idea.
  1. How to reset ECU
    By Mikea in forum Forced Induction
    Last Post: 05-21-2011, 10:38 PM
  2. O2 replacement, have to reset ECU ??
    By Coupe E36 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-15-2004, 09:47 PM
  3. Oil service/inspection service light reset isn't working
    By Doglass in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-20-2003, 02:42 AM
  4. How long to reset ECU
    By cal_guy19 in forum Forced Induction
    Last Post: 03-19-2003, 01:36 PM
  5. 100 octane - reset ECU - e36 Dinan S/C M3
    By Dinanify in forum Forced Induction
    Last Post: 07-09-2002, 08:36 AM
