Results 1 to 7 of 7
Thread: 2002 530i5 Rear suspension question
    May 2015
    Virginia
    E39, E39
    I Noticed that the inside of my rear tires are worn to the wires but the outside looks fine. The wear pattern looks the same on both tires. A few months back I hit some road debris on the interstate and got a 4 wheel alignment. I was told that the front and back was aligned within spec but couldn't be fully aligned because of wearing suspension parts. The car has 152k and all suspension parts are original with the exception of the front sway bar end links that I replaced.
    I'm not ready to do a full suspension overhaul right now since its starting to get cold and I would be working outside. What should I start with that would alleviate the inside tire wear issue and get me through the fall and winter until I can address the full 18 piece overhaul? Also, would this be a good time to do Sub frame bushings?
    Thanks in advance
    2013 Ford F-150 FX4 Ecoboost
    2002 530i/5 M-Sport
    1994 318i/5 (Up for sale Soon)
    Jun 2015
    Tennessee
    BMW
    You could go with a cheap Ebay rear suspension kit that comes with the control arms and rear ball joints, but your main issue is the rear ball joints in the wheel carrier. These need to be pressed out and pressed back in, but will alleviate the inner wear on your tires. You wont be able to do anything with your current setup to keep it from wearing if you replace the rear tires.
    A rear ebay kit will only be like $100 for ALL the parts needed, but it would be your best temporary option to have a smooth ride. Key word there is TEMPORARY. These parts while they feel good right after replacement will likely fail faster than OE/OEM parts.
    Yes of course it would be a good time to do subframe bushings.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by mebjr12 View Post
    Thanks in advance
    First things first, at 152k miles the car is definitely due for a suspension refreshing, and frankly I'd be surprised if it hasn't already had some. As the bushings wear, they will sag, and cause the rear tires to camber-in. It can become quite pronounced on old suspension.
    The E39 with all-new suspension naturally has two degrees of negative camber on the rear tires, so it is somewhat normal for the rear tires to wear down on the inside edge more quickly. However, you should also be checking the tire pressure. The rear tires, according to the sticker on the door jamb, should be inflated much higher than the fronts. The fronts should be at 33psi, rears at 41psi, IIRC. I run at 32/40 because my Contis are stiff-riding. Some forum members have religious tire pressure checking procedures.
    There are a lot of bushings in the rear suspension, and there are 2 adjustment points I think. There's the toe arm and the lower control arm (H-arm). Here's a good DIY that will help you interpret the alignment data. https://www.bimmerforums.com/forum/s...heel-Alignment
    Always get the alignment print-out from the shop's machine. It's very possible the guys doing the last alignment didn't do things correctly because they're just looking for "green" numbers on the machine. Rear toe alignment issues can cause excessive tire wear.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Here are some tire pressure + rotation tips for the detail oriented among us:
    https://www.bimmerfest.com/forums/sh...37&postcount=7
    https://www.bimmerfest.com/forums/sh...9&postcount=10
    Nate J.
    May 2015
    Virginia
    E39, E39
    Thank you both for the information.
    Sent from my SM-G955U using Tapatalk
    2002 530i/5 M-Sport
    Dec 2014
    orlando, fl usa
    2002 530iA sport
    Isn't excessive inner rear tire wear normal for sport package cars?
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    When you hit something, you may have bent something, or the alignment shop screwed things up.
    Also, 152K miles is a lot for NYC, and you definitely would need suspension work, but in VA everything may be just fine. My calculation is that ten Maryland miles, where I live, is the equivalent of one NYC mile, where the potholes are tank traps.
  1. 2002 525 Touring rear suspension question
    By Pauldexter in forum 1996 - 2003 (E39)
    Last Post: 09-06-2011, 08:49 PM
  2. Rear Suspension Question??
    By silverbeem in forum 1992 - 1999 M3 (E36)
    Last Post: 04-20-2005, 08:35 PM
  3. M3 Rear Suspension Questions...
    By Graffix000 in forum 1991 - 1999 (E36)
    Last Post: 11-01-2004, 12:53 PM
  4. quick rear suspension question
    By Yonkers320is in forum 1975 - 1983 (E21)
    Last Post: 03-03-2004, 06:53 PM
  5. E46 M3 rear suspension question?
    By Enigma in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-30-2002, 11:18 PM
