Results 1 to 12 of 12
Thread: Camber plates or Sway Bars
    Oct 2016
    PNW
    E36 M3 Coupe
    So I’m currently building my track car. I found some Eibach front and rear sways for very cheap which I need but I also need front camber plates so I can get my alignment dialed in. I can’t afford both right now but I have the money for the sway bars. What do you guys think I would see more benefits from on the track? Sway bars or camber plates and proper alignment?
    Oct 2016
    PNW
    E36 M3 Coupe
    Went with sway bars. Thanks for your guys help
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    I was going to say sways, there are a number of ways to adjust camber is you don't mind having to run that specific alignment full time. Also, consider just a front bar.
    Oct 2016
    PNW
    E36 M3 Coupe
    I got eibach adjustable so I was going to start with front set stiff and the rear set soft.
    Jan 2005
    Huntsville AL
    1997 M3
    I second his opinion on just a front bar. I've tried both and a stiff front with factory rear put the power down much better. In the end do what you feel is best, just sharing experience.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from Track Car Builds.
    88M3 AW 43k miles Project FS
    May 2015
    Easton, PA
    1996 BMW 328is
    In order to get my body roll under control, I started with the big Hotchkis swaybar in front only. I then added Camber plates....but it wasn't until I did springs (H&R Race) that I was satisfied with the setup. If I had to do it over, probably would have started there.
    Oct 2016
    PNW
    E36 M3 Coupe
    I found out from a friend that this is the route to go. So I’ll prolly be picking em up. Buddy with pss9s said they feel better because higher spring rate
    Bergenfield, NJ
    Quote Originally Posted by Wastatepride View Post
    I dont know what rates you are going with but just keep in mind that PSS9 can't handle the same amount of spring as a fully race damper (MCS/JRZ etc).
    Oct 2016
    PNW
    E36 M3 Coupe
    Thanks. I’m going to go from H&R sports/bilstein strut to h&r race/bilstein
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    My experience with H&R race is that they are not stiff enough for the height … as in you bottom out under heavy load, and hit the bump stops. Very bad for handling … they are stance springs only.
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    May 2015
    Easton, PA
    1996 BMW 328is
    Quote Originally Posted by ScotcH View Post
    This wasn't my experience....I'm using the H&R spring with Bilstein B8 (ride height is not adjustable) so not ridiculously low...also on 200TW tires, so it's possible that's a factor too.
  1. E36 Camber plates/Front sway bar
    By 1995M3LTW in forum BMW Parts Wanted
    Last Post: 04-27-2012, 10:56 AM
  2. E36 Turner Camber Plates and Strut Bar
    By Tom R in forum Suspensions, Springs & Shocks
    Last Post: 03-16-2012, 05:29 PM
  3. Camber Plates + front strut bar question
    By BlueBullet328 in forum 1991 - 1999 (E36)
    Last Post: 10-25-2007, 11:37 AM
  4. Camber Plates and Strut Bar
    By z3papa in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-27-2007, 02:00 PM
  5. WTB: Adjustable Rear Camber Arms and Sway Bars.
    By BMW02 in forum BMW Parts Wanted
    Last Post: 01-10-2007, 10:53 AM
