Results 1 to 5 of 5
Thread: ZF trans Clutch issue
    Oct 2018
    Sacramento
    1995 325i
    I recently swapped a ZF transmission into my 95 325i after blowing second gear. Prior to the swap I had no clutch issues but as soon as I finished the swap I got horrible clutch slip. After bleeding the original 325 trans master cylinder the clutch felt a little better but still slipped under load. I can normally drive the car but clutch kicks or downshift accelerations just make the clutch slip. Has anyone had any experience with this previously or can recommend something to fix this?
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    What did you use for clutch parts? It sounds as though the clutch is not engaging fully. Being right after you swapped the transmission I would suspect some part incompatibility. You likely don't have enough pedal free travel, and the clutch engagement point is really high. There are a couple things you could do but more information would be helpful.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    Quote Originally Posted by jc43089 View Post
    What he said and did you put the throw out bearing back in correctly. I've seen people just put it on over the spline resting on the fork instead of attaching it.
    Oct 2018
    Sacramento
    1995 325i
    The clutch engages fine. There’s only issues during harsh acceleration and clutch kicks
    Apr 2015
    Tennessee
    1998 BMW 328i
    My friend just did a manual swap on his 328i and he had clutch issues galore. First it wouldn't bleed, then it bled but it wouldn't shift into gear while running. Then it would shift into gear but the clutch was still engaging even with the pedal pushed all the way in. He ended up having to modify the length of the slave cylinder rod to fix it
  1. FS: M50TU, ZF trans, Clutch/PP, OBD1 stuff, Edirtystuff
    By 328iJunkie in forum Georgia sponsored by Harrison Motorsports
    Last Post: 04-16-2010, 02:33 PM
  2. E36 M50 complete with harness/ECU, ZF trans, Clutches
    By 328iJunkie in forum Engines, Performance Parts & Software
    Last Post: 04-13-2010, 09:00 PM
  3. WTB: ZF trans, clutch and DS
    By Boarderx192 in forum BMW Parts Wanted
    Last Post: 04-06-2009, 04:08 AM
  4. WTB: ZF trans, clutch, flywheel, DS
    By Boarderx192 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 04-05-2009, 09:40 PM
  5. WTB: E36 ZF trans, clutch, flywheel and DS
    By Boarderx192 in forum Whole Parts Cars
    Last Post: 04-05-2009, 09:31 PM
