RM European Auto Parts
Results 1 to 6 of 6
Thread: Wheel rubs strut housing only on passenger side? Bent housing or knuckle?
    Nov 2008
    Eugene, Oregon
    e30, e34, e36, Cherokee
    I went to put my new 17x8 et20 tsw wheels on and 245 45 bfg sport comp 2s and the left side cleared with a good 1/4 inch while the right side rubbed against the weld for the spring perch and the dips in the perch.
    Wtf? Bent knucke or housing right? Theres no wheel bearing play.
    I "made" it fit. A BFH and a little grinding on that weld. But i want to know wtf is going on and fix it before it ruins my new tire.
    Sent from my SM-G960U using Tapatalk
    Slowly climbing the ladder. But never reach the top.
    Click Car 4 Build!
    '86 325es-Turbo m30!
    '94 325iA-Clean DD
    '94 530i
    -6 Spd swp
    '89 Cherokee 4x4-4.7L stroker
    '97 Eclipse Spyder-4g64/63 stroker Turbo.
    '89 535is-RIP 2020, engine now in e30!
    '84 318is-RIP 2016.
    '89 535iA-Parted 2012
    94' 530iA-RIP 2004, engine in new 530i
    '78 530ia-first car RIP 2005
    Aug 2013
    1999 BMW M3 Coupe
    Have you had a professional alignment recently? Does your front camber match side to side?
    I agree, it looks like something is damaged/bent if it's really that far off side to side on a car without camber plates or anything like that. Control arm or knuckle would be my guesses.
    Nov 2008
    Eugene, Oregon
    camber plates/control arms would not affect the relation of the wheel hub to the strut housing... Only the angle of the entire assembly.
    I had to look at it for a minute and wonder if I put something together wrong but you cant and nothing changes that relation HUB | | STRUT Camber plates or e32 control arms ins second slot HUB / / STRUT The relation angle and distance stays the same is what I am trying to show.
    No I was going to tomorrow or Monday send it across the street for alignment and if its all F'ed up on that side well then I'll know.
    Currently it pulls a bit to the left and the steering wheel is a bit to the right...
    Click Car 4 Build!
    '94 325iA-Clean DD
    '94 530i
    -6 Spd swp
    '84 318is-RIP 2016.
    Aug 2013
    1999 BMW M3 Coupe
    Yeah you're right now that I think about it. It must be the knuckle/hub alignment relative to the strut as you said. I assume the bolts holding the strut to the knuckle/hub are all intact and there's no sign of damage/bending on the bottom portion of the strut where it joins the hub? I think those flanges where it bolts together and joins would be the place where it would bend in any impact.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I think you’ve got a damaged/bent “king pin” or knuckle. It’s item #2 in the link: http://www.realoem.com/bmw/enUS/show...diagId=31_0518
    Nov 2008
    Eugene, Oregon
    e34s the strut housing and knuckle are all one piece they do not separate like newer cars.
    But yes, bent knuckle it must be.
    I'm gonna get the alignment checked Monday.... Or maybe I should just get a junk yard knuckle/strut housing put it on then get the alignment. I mean I pretty much know its F'ed up.
    Click Car 4 Build!
    '94 325iA-Clean DD
    '94 530i
    -6 Spd swp
    '84 318is-RIP 2016.
  1. WTB: E36 passenger side mirror housing
    By swtyphoon in forum Exterior Lighting & Body Parts
    Last Post: 05-08-2010, 12:20 AM
  2. Headlight housing for e39 passenger side
    By BIGHODIE in forum BMW Parts Wanted
    Last Post: 08-11-2008, 10:15 AM
  3. WTB: Passenger Side DEPO Housing
    By kcar73 in forum BMW Parts Wanted
    Last Post: 07-07-2007, 11:16 PM
  4. WTB: Passenger side DEPO Housing
    Last Post: 11-02-2006, 02:36 PM
  5. Replies: 2
    Last Post: 10-16-2005, 12:44 AM
