Results 1 to 6 of 6
Thread: 2001 Z3 antenna grommet
    Jul 2014
    tallahassee, fl
    2001 BMW Z3
    Thought I'd share this recent project, about $13 part and 10 minutes to fix. I was able to unscrew the antenna with my hand, I then taped up around the old grommet to prevent any accidents to the paint. I used some needle nose pliers to pick the old grommet out, it was dry and came out pretty easy. I found a long screw with matching threads and screwed it in to allow us to pull the antenna internals up while pushing the grommet in. I used some dielectric grease I had to lube up the new grommet, I slid it into the hole and pulled the antenna mount through the new grommet. It requires a pull and turning motion to get the grommet to seat correctly. It got pretty tight near the end and I 'carefully' used a pair pliers to do the last quarter turn. See pics for more info.
    Tallahassee
    1998 Z3 M Roadster.
    Paul!
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    That's the first time I have seen it done with the antenna base left in place. Didn't know that could be done.
    I did it by loosening the base and pulling it down to get the nipple out of the fender, to make more room for putting in the grommet.
    BMW MOA 696, BMW CCA 1405
    Sep 2017
    South Central PA
    '00 Z3 2.3 Roadster
    I'm going to try this method, I can't get my new grommet to seat all the way down--- tried disconnecting the base, lubing with silicone, etc. Of course the warm weather is now gone, so I'll have to heat it up a little with the hair dryer first.
    Jul 2014
    tallahassee, fl
    2001 BMW Z3
    Hey Steve!
    Nov 2005
    LI, NY
    99 M Roadster
    I did mine a couple of weeks ago, tried unscrewing the antenna itself (was on there really tight) and the antenna base tip cracked right off. Had to buy a new antenna base. Whoops.
  1. Z3 antenna grommet
    By s10blades in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-05-2015, 05:22 PM
  2. Z3 E36/7 Need used yaw sensor for 2001 z3 2.5
    By kimzem in forum 3 series & Z Series
    Last Post: 07-20-2010, 06:24 PM
  3. Z3 E36/7 FS: 2001 Z3 3.0i Coupe, Silver/Black, 5 Speed, Only 57k Miles
    By PDWebb in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-30-2010, 10:03 AM
  4. Z3 E36/7 FS: 2001 Z3 3.0i Coupe, Silver/Black, 5 Speed, Only 57k Miles
    By PDWebb in forum 3 series & Z Series
    Last Post: 03-18-2010, 06:44 PM
  5. Z3 E36/7 WTB rebuilt or new 2001 Z3 coupe seat motor
    By ross96 in forum BMW Parts Wanted
    Last Post: 10-14-2009, 08:19 AM
