Results 1 to 16 of 16
Thread: Square fitment: 18x9 ET24 with 265/35/18: will it fit?
    San Diego, CA
    S54 and S62
    I have a moderately lowered 540iT (-20mm front, -15mm rear) and looking to upgrade from my stock setup (edit: which is 17x8 ET20 235/45 and 17x9 ET26 255/40).
    Not sure if I can get away with running 265/35/18 square or if I should play it safe with 255s instead. I don't mind running a small spacer upfront if necessary to clear the strut but I really don't want to rub anywhere.
    TIA
    Current:
    Alpine White E46 325i Touring S54 6MT
    Titanium Silver E39 540i Touring M-Sport S62 6MT
    Past:
    Alpine White E46 330i ZHP Sedan S54 6MT
    Interlagos Blue E85 Z4 M Roadster 6MT
    Le Mans Blue E92 M3 6MT
    Japan Red E46 325i Touring S54 6MT
    Estoril Blue Individual E46 M3 Coupe 6MT
    Cosmos Black E36 M3 Coupe S54 6MT
    Alpine White E92 M3 6MT
    Alpine White E90 M3 6MT
    Laguna Seca Blue E46 M3 Coupe 6MT
    Jet Black E36 325is S52 5MT
    Lagoon Green E36 325is 5MT
    Jan 2017
    CT
    2011 750Lix M sport
    I’m having same dilemma right now as I’m looking to purchase new tires so I’m curious to hear the thoughts on this...
    Current setup:
    18x9 Style 42 square setup with 245/40 tires all around. Front is lowered with H&R sport springs on Koni Yellows....I also have 15mm spacers. There are no issues with rubbing.
    Whittier
    2004 525i
    Quote Originally Posted by Kaiv View Post
    I have a moderately lowered 540iT (-20mm front, -15mm rear) and looking to upgrade from my stock (17x8 235/45/17) square setup.
    Not sure if I can get away with running 265s or if I should play it safe with 255s instead. I don't mind running a small spacer upfront if necessary to clear the strut but I really don't want to rub anywhere.
    TIA
    17x8 to a 18x9 is one inch difference= .5 inch closer to the strut and .5 inch closer to the fender..
    .then the -20ET vs the-24et ...the 24et is placing the wheel closer to the strut by at least 4MM. 17mm total towards the strut (per tire calculator found online)
    then you have the sidewall clearance.
    if you increase the width of the rim will, you will have to decrease the ET numerically lower. Most ETs above 20mm will need spacers
    San Diego, CA
    S54 and S62
    Quote Originally Posted by 525i Enjoy View Post
    Thanks, I understand how offsets work, I was mainly looking for real world experience Search results were inconclusive, lots of contradicting info.
    Anyways, I just realized my stock wheels are staggered (all this time I thought I had 17x8 square ) so I went and bolted a rear wheel (17x9 +26 255/40) up front. It sat tight against the strut but well within the fender.
    At this point I think the 18x9 +24 will fit nicely with a 10mm spacer. Still unsure about the tire size though. 255/35/18 would definitely work since the width and diameter is identical to the 255/40/17 but the sidewall would be 12.5% thinner and I don't really like skinny rubberband sidewalls. A 265/35/18 would have a fatter more stock-like sidewall but will it fit? Back to my original question I guess!
    Quote Originally Posted by Dvbimmerk View Post
    Current setup:
    Please share some pics I have the same springs and my 18x9 have the same offsets!
    Current:
    Past:
    Jan 2017
    CT
    2011 750Lix M sport
    Please share some pics I have the same springs and my 18x9 have the same offsets![/QUOTE]
    San Diego, CA
    S54 and S62
    Not bad at all. Looks less stretched than I expected.
    I took some measurements and decided to order some 265/35. I'll report back when I get them mounted.
    Current:
    Past:
    Jul 2006
    burnaby b.c
    1998 328is 1999 540iT
    YES it'll fit, mine is 18x10.5 275/35 square +25 rear and +17 front to clear the strut.
    95 318is - m52 powered, 97 328is - M-package, ​01 540iT/6speed
    San Diego, CA
    S54 and S62
    Ended up going with 3mm spacers all around. Wheels and tires are 18x9 style 37s and 265/35 contis. Fronts spacers were required to clear the struts. Looks great and fits great IMHO!
    Current:
    Past:
    707 CA
    naggin' wagon
    Looks good!
    1994 325is (2006-2010) -- 1989 325i M50 Swap (2011 - 2014) -- 2001 525iT (2018 -Current)
    Mar 2005
    Charleston, SC
    99 528iT
    I've got 18x9 front and 18x11 rear with 265/35/18 all around on konis and h&r sports. No rubbing, no spacers
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    I always thought style 37 9” rears was hold look good all the way around. Can you post more pictures?
    San Diego, CA
    S54 and S62
    Quote Originally Posted by BimmrMeUpSnotty View Post
    Sorry, I hadn't logged in in a while. Here's a couple pics.
    Current:
    Past:
    Feb 2014
    Alexandria, VA
    Thanks! It looks really good. So that was 3mm spacers, stock front struts? Sorry if I missed it in earlier posts
    Jul 2012
    mitten
    525it,02 525it,73 2002
    Great Touring, the silver and MPars are timeless. Beautiful
    San Diego, CA
    S54 and S62
    Correct, stock struts and 3mm spacers.
    Thanks!
    Current:
    Past:
    Dec 2016
    Canton, Ohio
    97 528i
    Nice looking car...
    "two wrongs don't make a right...only three lefts do...."
    '79 Euro 635csi - gone and regretting it...
    '89 gsxr-750 - former traffic knife
    '97 528i sedan - holding on strong...(just sold after 16 years of ownership - sad day)
    '03 Euro 525it - something about a famous dolphin.....
    '06 Mercury Grand Marquis (don't ask....it gets the job done....)
    '84 Specialized Allez - full Campagnolo Super Record
    '99-ish Cannondale CAAD4
    "Stinky" - Kona Stinky Five
    '86 528e
    2008 E70 X5 3.0
  1. Replies: 1
    Last Post: 11-04-2014, 04:17 PM
  2. **||Apex Arc 8 18x9.5 +22 265/35/18 Hankook RS2||**
    By Narvin in forum Wheels and Tires
    Last Post: 11-04-2014, 12:36 AM
  3. Replies: 4
    Last Post: 10-05-2013, 11:18 PM
  4. Will 285/35/18 and 265/35/18 on 18x10 and 18x9 fit
    By Dustin540i in forum 1996 - 2003 (E39)
    Last Post: 10-11-2004, 01:44 AM
  5. Help :ASA AR1's 18x9 w 265/35/18's Front and Back?
    By c1540i in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-01-2004, 08:31 AM
