Results 1 to 3 of 3
Thread: Turner Motorsport Software and Test Pipe Bundle
    Mar 2001
    Amesbury, Massachusetts
    BMWs and Mini's
    Shop Turner Software and Test Pipes Here
    For a performance upgrade on your E90/E92 M3 there is nothing better than the cat-delete with specialized software. This combination produces over 40whp and 30wft-lbs with no other modifications - a massive gain on an already impressive engine!
    Our Race software has been fine-tuned over the years beginning with our IMSA/CTSCC E92 M3 racecars (2011 GS class champions). We modify over 40 different maps in the ECU for such things as fuel and timing maps at part throttle and full throttle, revised torque settings, knock control, VANOS and cam timing, pedal input, top speed limiter, and rev limiters. Additional tuning has been done for the cat delete - prevent limp mode and check engine lights, fault codes for cat delete, and turning off the secondary air pump (to satisfy race series regulations). Turning off the secondary air pump also disables the cold start sequence so your idle and warm-up will be smoother and quieter. A built-in cold start rev limiter safeguards the engine internals until the oil warms up. Not only is there a lot more power at all RPM but the engine is more responsive and smoother!
    E9X M3 Stage 2 Power Gains:
    SpecPower Gain (Engine)Torque Gain (Engine)
    Software upgrade alone+17hp+19ft-lbs
    Software and Test Pipes+48hp+33ft-lbs
    Our software is installed via the Turner flashing OBD tool. This tool plugs into the OBD socket in the dash and the performance software is installed from a laptop computer connected to the tool. It also works as a fault code scanner to read and reset diagnostic trouble codes and reset adaptations. The software program requires a Windows XP/Vista/7/8/10 laptop and the installation and setup are very easy. The OBD tool, cable, and files are shipped to you with simple setup instructions. There is no need to remove your ECU and ship it. You can have your M3 flashed in under an hour from the convenience of your garage or driveway!
    Call or email to order and get a free Turner T-Shirt and Plate Frames! 800.280.6966 or info@turnermotorsport.com
    Turner Motorsport
    / // Parts and Performance for BMWs
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
    Mar 2001
    BMWs and Mini's
    ​Now 10% off!
    Turner Motorsport
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
    Mar 2001
    BMWs and Mini's
    Black Friday Pricing - 17% off
    Call or email us today! 800.280.6966 or info@turnermotorsport.com
    Turner Motorsport
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
  1. Turner Motorsport N52 3 Stage Intake Manifold w/Software Bundle
    By TurnerMS in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 10-11-2018, 02:01 PM
  2. E36 95 M3 Dinan and Turner Motorsports Software
    By asdfbunk in forum Engines, Performance Parts & Software
    Last Post: 11-05-2011, 03:23 PM
  3. Just ordered my Turner Motorsports software upgrade
    By BMW&PorscheDude in forum 1991 - 1999 (E36)
    Last Post: 06-13-2011, 06:16 PM
  4. Turner Motorsports Software
    By NikosX in forum 1988 - 1996 (E34)
    Last Post: 03-09-2005, 03:03 AM
  5. Replies: 2
    Last Post: 01-24-2005, 11:44 AM
