RM European Auto Parts
Results 1 to 5 of 5
Thread: Broken front strut, tie rod help
    Jun 2018
    Winnipeg
    2008 BMW 323i
    I broke my front driver's strut, to get it out no problem . To put the new one in hell. Tried to remove as little as possible, I have to take off the whole hub. I having trouble removing my tie rod end nut. The threaded part has a hex opening, the nut looks like it has clasps around the bottom of it. The clasps look like part of the tie rod when manufactured. What should I do?
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello - take a look at the links below to our site's DIY tech articles on the procedures. Please let us know if you have any questions or if we can assist with any future part needs.
    https://www.pelicanparts.com/BMW/tec...eplacement.htm
    888.280.7799 | 6am - 5pm PST
    New York
    1974 2002, 2009 128i
    If you've got it, an impact - air or electric - is going to make your life a lot easier here. And if you actually broke the strut, are you sure nothing else is damaged?
    Life's tough. It's tougher when you're stupid.
    -John Wayne
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    "Take off the whole hub"? No, no you don't. Really, this job isn't that hard.....except, I was going to say....if you live in a northern state, where salted roads rust everything to bits. Yeah, this will be difficult for you, because of the rust. When you break the bolt for the clamp holding the bottom part of the strut, dealing with it on the ground, in your driveway is going to be a horrible experience.
    But seriously, the Pelican instructions above are just fine -- DO NOT listen to the guys below the main body of text; some of those "hints" are incredibly stupid.
    Here's a link to the BMW factory service manuals (and even wiring diagrams) for your car:
    https://www.newtis.info/tisv2/a/en/
    Do you have a strut compressor anyway? Doing the swap of spring, etc., without a good strut compressor is dangerous. And of course, you ARE changing both struts, right? And the strut mounts? Not doing both struts, and the mounts/bearings, is very bad.
    Chris Powell
    BMWCCA 274412
    Jun 2018
    Winnipeg
    2008 BMW 323i
    I got it out and in It's all good and torqued. Fixed that, and now a brand new problem
  1. Strut/Shock/Tie Rod Help?
    By aschroeder92 in forum 1975 - 1983 (E21)
    Last Post: 05-25-2008, 12:09 PM
  2. Strut/Shock/Tie Rod Help?
    Last Post: 05-24-2008, 10:31 PM
  3. Front strut bump stop help
    By Malcolm in forum 1991 - 1999 (E36)
    Last Post: 01-28-2006, 05:27 PM
  4. Set of fogs, Passenger front side Tie Rod Assembly for E36
    By Solidhead in forum BMW Parts For Sale
    Last Post: 11-07-2005, 10:46 PM
  5. WTB: Shocks, Struts, Tie Rods
    By adeelpowers in forum BMW Parts Wanted
    Last Post: 05-22-2004, 04:35 PM
