I recently discovered that my BBCV is broken and I trying to figure out how much this vacuum valve contributes to the idle of the vehicle. Thanks in advance for your help answering this boggle.
V/R Zachary Pullins Sr.
Florida Suncoast Chapter BMWCCA
2016 Cadillac SRX & 1999 E39 540i/Sport
" Vision without resources is just hallucination"
You mean the jet suction valve thats between the brake booster and the CCV?
Depends how bad it's broken, the engine can stall or just run rough and throw a code.
First of all... lets explore terminology... While I won't jack you up too hard on calling it a "brake booster check valve".. its real official BMW name is "sucking jet pump". Apparently some parts vendors have taken to calling it this BBCV term I guess... but its definitely well more than just a check valve... its a venturi vacuum amplifier thing...
But if you want to search for info on it a lot of threads will call it by its proper name - the "Sucking Jet Pump". (not that the official name is that great either... but it is what it is...)
Now: Is the question "how much can a leak there cause an idle problem?" If so - as Jim says - depends, but could be as much as "a lot".
But, if the question is "how necessary is the sucking jet pump?" - the answer seems to be "not very". Some owners have deleted it and reported a virtually undetectable difference in brake effort. However, its supposed to be there, and its supposed to be an integral part of providing brake boost. I dunno. I'd keep it myself unless there's some overriding need to re-engineer it. You wouldn't want to find out that "its undetectable except under conditions of emergency braking from 70mph down to zero when hurtling towards a large fixed object and/or busload of nuns & orphans, in which case it suddenly makes a big difference".
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
I'd have to look at the internal setup to know if this helps keep vacuum in the booster (probably does) if the engine suddenly dies. There are 2 "check valves" inside.
