Results 1 to 25 of 25
Thread: 540i no start
    Apr 2018
    Charleston
    '94 325i, '98 540i
    540i no start
    I've got a 98 540i, been running fine. Parked it for an hour and all of a sudden it won't start. Cranks and cranks but won't fire up.
    Things I've checked:
    Fuel- getting power to the fuel pump, 11 volts while cranking
    Crank position sensor - shot the sensor and it's reading ~650 ohms through it
    Pulled MAF sensor and tried to start
    Haven't checked for spark yet that's the next thing I'll be doing.
    So far I've gotten a few ideas on what it could be, I've heard the crank position sensor, EWE could be out of sync, jumped timing (Cam chain guides were done within the last year and a half)
    Any ideas or things I could check? Don't want to just chuck money at it for no results
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Am I reading that correctly?
    You have 11V at the battery?
    That likely won’t start.
    Measure battery voltage. If less than 12.5V it is dying. Charge it up (either this or new) and try again.
    2001 750iL DD74441
    Stock
    RIP: 2003 540iA Sport GS56111
    H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
    Apr 2018
    Charleston
    '94 325i, '98 540i
    When it's not cranking it gets 12.5v at the battery, but when cranking it'll drop down to about 10v
    San Jose, CA
    1997 BMW 540i 6 speed
    Have the battery load-tested. It may be weak, but 10V s/b enough to start it.
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    540i no start
    I am guessing your battery may be at EOL (End Of Life). How old is it?
    Check the chart below (thank you Timm) In SC you are likely about 80 so a 12.5 is less than 50% state of charge. Charge it up or replace. Try a jump.
    You can also try for any codes, but low voltage will cause a no start.
    Edit: to Ed’s point, a low charge state will cause sulfation and basically kill it.
    2001 750iL DD74441
    Stock
    Apr 2018
    Charleston
    '94 325i, '98 540i
    Tried it with a jump, battery alone is reading 11.7 volts so it's dead as hell. Going to throw it on a charger overnight and see if they makes any difference. Just weird to me it was running fine all day and then after sitting for an hour suddenly won't start
    Dec 2013
    Chicagoland area
    EXOTICS
    Does the tach on dash display rpm while cranking?
    You have voltage at pump, but have you heard it power up/prime the fuel lines?
    If not, test fuel pressure at rail.
    Apr 2018
    Charleston
    '94 325i, '98 540i
    I actually don't recall if it shows the RPM while cranking. What would that indicate if it doesn't?
    Dec 2013
    Chicagoland area
    EXOTICS
    Also check sparkplugs, if over 50,000mi-replace them.
    If cause of no-start still not found, I would scan for codes.
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by turboSlow View Post
    Possibly a faulty Crank Position Sensor, verified by a fault code obtained by a diagnostic scan. I would check wiring and connector first.
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    See if it will start and run for a few seconds on starting fluid.
    Dec 2013
    Chicagoland area
    EXOTICS
    No, not recommended for use on plastic BMW manifolds, for obvious reasons, too volatile,
    use a cleaner spray like carb cleaner, brake clean...etc.
    Apr 2018
    Charleston
    '94 325i, '98 540i
    Cranked it and checked for RPMs on that tach, didn't move at all. Going to order the crankshaft position sensor tonight. Hopefully that fixes it.
    May 2014
    jacksonville, fl
    2014 BMW 535i MSport
    I’ve had this problem happen a long time ago and it ended up being a broken timing belt. Hopefully this is not your issue but it couldn’t hurt to check that or at least the timing.
    Sent from my iPad using Tapatalk
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by rifleNruck View Post
    You'll be checking for a long ass time trying to find a timing belt on an M62 engine.
    M62 timing chain guides fail famously but they don't look like this when they do.
    The dead / killt battery is hugely suspicious. What took out the battery in the first place? Maybe a short? Water in something?
    Reading codes would be a great thing to try to do.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Apr 2018
    Charleston
    '94 325i, '98 540i
    Update:
    Replaced the crank position sensor. I'm getting spark and fuel, but still will not start. Idle air controller is good, it turns freely when I take it out. Tomorrow I am going to check the fuel pressure and probably replace the cam sensor. I tested it and it did not give me an Ohm reading on any combination of the 3 terminals on it. Any ideas?
    Mar 2010
    Dudebro. READ CODES. If you must, just use a generic scanner (not the best by far for a BMW but better than stabbing in the dark).
    Typical sudden crank-but-no-start conditions could be:
    - Fuel pump death (did you check actual full pressure or just 'gas comes out of the lines'?)
    - Crank or cam sensors
    - EWS sync
    - Other electrical gremlins/shorts/failures including ignition switch, passenger footwell water, ground/power cable connections
    Some of the above do not leave codes behind - or in cam/crank case, 'sometimes do and sometimes don't' - but its always best to exhaust that avenue first anyway to see if there's anything the computer is actually desperate to help us with in diagnosing.
    Given we know the battery pooped the bed for sure, the EWS sync could have been lost from drastic voltage drop during an attempt to crank. A proper BMW scan tool will retrieve a code pointing directly to this. A OBD Peepee-code scanner might show that code as something a bit more obtuse but still may show it.
    2003 M3CicM6 TiAg
    Former:
    Apr 2018
    Charleston
    '94 325i, '98 540i
    I did read the codes, nothing but evap emissions code and intake air temp sensor is bad. Neither of which would cause a no start. I'm renting a fuel pressure tester tonight as I think its not getting enough fuel pressure.
    Apr 2018
    Charleston
    '94 325i, '98 540i
    Couldn't test fuel pressure because my rail doesn't have the schrader valve. Next thing I'll try is testing compression/cylinder bore wash from trying to start so much
    Mar 2010
    Huh. Does the old 540 have a fitting atthe 3/2 valve maybe?
    2003 M3CicM6 TiAg
    Former:
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Update:
    If you meter is good then your IAC is bad. Replace it and if it still doesn't start use some starter fluid.
    I've used starter fluid for years, never had any problems using it. You only need two 1/2 sec squirts.
    Apr 2018
    Charleston
    '94 325i, '98 540i
    Well, I pulled the plugs, cleaned them, put some oil in the cylinder to help with compression for bore wash, and she tried to start but then wouldn't even pop after that. It sounded SO close to catching
    Dec 2013
    Chicagoland area
    EXOTICS
    To do list:
    • Compression test
    • Fuel pressure test
    • List of codes
    • List of results of the tests for us to view.
    I would focus on the fuel pressure and fuel pump/filter, fuel pump relay,
    as that seems to be most likely the cause of the no-start condition.
    Apr 2018
    Charleston
    '94 325i, '98 540i
    How would I go about checking fuel pressure? There is no schrader valve and everything I can find online and in the forums says there is one on the end of the fuel rail but there definitely isn't on mine.
    Dec 2008
    Long Island
    528iT
    This. It's definitely on there somewhere. Or even at the end of the rail. I remember seeing them when I worked at the dealer.
  1. 540i No Start Trouble Shoot
    By kmoy2002 in forum 1996 - 2003 (E39)
    Last Post: 06-24-2008, 09:01 AM
  2. 540i Wont start or crank
    By bhootM5 in forum 1996 - 2003 (E39)
    Last Post: 07-04-2007, 12:15 PM
  3. 540i Sport Starting Issue
    By jbiel in forum 1996 - 2003 (E39)
    Last Post: 11-19-2006, 01:02 AM
  4. 97 540i not starting.
    By 318qship in forum 1996 - 2003 (E39)
    Last Post: 04-19-2006, 12:35 PM
  5. please help: 98 540i wont start!
    By frankthetank528 in forum 1996 - 2003 (E39)
    Last Post: 12-20-2005, 12:52 AM
