Results 1 to 11 of 11
Thread: parts list for timing chain guides?
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    I have been slowly putting together the parts to replace the timing chain guides when I pull the VANOS to get them rebuilt. I saw the suggestion for the oil separator, and bought the parts, but I was wondering if someone made a complete list. I have been clicking on multiple threads but I'm always open for more advice.
    Jun 2015
    Tennessee
    BMW
    The timing chain guide champion has posted his list several times. I would look around for his threads or PM him directly. If you do not know who the timing chain guide champion is...you have not done enough research.
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    Quote Originally Posted by WBAD530i View Post
    understood
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Here is my thread and list of parts:
    https://www.bimmerfest.com/forums/sh.../topics/917747
    Could I be missing some? Yes. A lot of it is “optional” or “while you are there” and I didn’t do all of those.
    2001 750iL DD74441
    Stock
    RIP: 2003 540iA Sport GS56111
    H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    Quote Originally Posted by TheAngryBear View Post
    2001 750iL DD74441
    Stock
    Sep 2014
    KS
    e24e30e36e39e90
    Guides, Gaskets, O Rings, Misc Part Qty >1
    Cylinder Head Oil Check Valve (E38 E39 E52 E53) - 11121706921 (x2) 11121706921 2
    Oil Separator (540 740) - 11151705272 11151705272
    Seal Ring-Crankshaft tensioner rubber grommet - 11141736758 11141736758
    Center Crankshaft Bolt - 11231736585 11231736585
    Crankshaft Seal Front - 11141275466 11141275466
    Timing Chain Guide Rail - 11311741777 11311741777
    Timing Chain Guide Rail - 11311741236 11311741236
    Timing Chain Guide Left Lower - 11311745406 11311745406
    Timing Chain Guide Upper - 11311435028 (x4) 11311435028 4
    Timing Chain 11311741746 11311741746
    VANOs Chain Tensioner O Ring 07119906361 2
    Distribution Housing Gasket Left (Cylinders 5-8) - 11361705579 11361705579
    Distribution Housing Gasket Right (Cylinders 1-4) - 11361705578 11361705578
    Oil Pan Gasket - 11131436324 (540i/740i) 11131436324
    Oil Dipstick O-Ring - 11431707164 11431707164
    Oil Level Sensor O-Ring - Victor 12611744292 12611744292
    Valve Covers & Timing Covers
    Valve Cover Seal Washer - 11121437395 (x16) 11121437395 16
    Valve Cover Seal Washer - 11121721879 (x6) 11121721879 6
    Valve Cover Gasket Set Left - 11120034105 11120034105
    Valve Cover Gasket Set Right - 11120034104 11120034104
    Upper Timing Cover Seal Strip (Cylinders 5-8) - 11141741128 11141741128
    Upper Timing Cover Seal Strip (Cylinders 1-4) - 11141741127 11141741127
    Timing Cover Gasket Set Lower - 11141436978 11141436978
    Cooling System
    Water Pump 11510393336
    Water Pump Gasket 11511731372 11511731372
    Thermostat 11531436386
    BMW Coolant - 2+ gallons 2
    Coolant Pipe O-Ring - 11531710048 11531710048
    Coolant Pipe O-Ring - 11531710055 11531710055
    Alternator Gasket/O-Ring - Bosch F00M258503 F00M258503
    Belts & Pulleys
    alt belt 11287636377
    ac belt 11287636376
    adj pulley 11287515865
    adj pulley 11281742859
    tensioner 11281745545
    Coolant Hoses
    coolant hose 11537505229
    coolant hose 11537505228
    coolant hose 11537511207
    coolant hose 11531711385
    coolant hose 11531711381
    coolant hose 11531711384
    O ring for hose 11531711384 11537501777
    coolant temp sensor 13621433077
    Oil Filter
    Motor Oil - 8+ quarts
    Timing Chain Tensioner Lower - INA 11317531813 11317531813 *This tensioner was replaced in last 18 months with upgraded design, can be re-used
    Camshaft Solenoid Gasket - 11141435023 (x2) 11141435023 *These gaskets were replaced a few months back, can be re-used
    Sep 2014
    KS
    e24e30e36e39e90
    This list is much more readable with the Default style, looks terrible on the Mobile style^^
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    This list has been done boatloads of assloads of shi7loads of times. If you can't come up with 3-4 versions in 10 minutes then your google-fu is weak.
    Personally I think an "annotated" version with a column for comments like siennamilleyr sorta has done there for his own job (w/ the *'s) would be great. His list has some stuff, but for instance, if you haven't done valley pan that's an obvious one to knock off while you're there...
    There's a bunch of stuff that deserves caveats. IF it was written up properly it'd consider that all owners dont' have same needs/perspectives/engine-requirements...
    Like bunch of stuff is really "optional only if your car is really abused and/or you want to go overboard" examples:
    - check valves (pulling and cleaning them and redoing the seals probably is adequate for most people whose motors aren't real gunked up)
    - distribution block gaskets (may not be necessary to disassemble at all if no leaks - I didn't pull them at all... many do not with zero problems...)
    - chains (may not be necessary at all on all but the highest miles motors, the chains are super robust and tend to show very little wear on decent engines...)
    - camshaft sealing rings (may be necessary for very early motors but not later ones)
    I should add "etc." cuz that's all just "top of the head" hsit.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Here’s the list I’ve used for the last 18 guide jobs I’ve done: https://docs.google.com/document/d/1...HfPXDj0Y__bigM
    Let me know if you have any questions, happy to help.
    1995 525i 5-speed - Thread
    Sep 2014
    KS
    e24e30e36e39e90
    The list I posted was mostly based on that list ^^
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    Quote Originally Posted by dannyzabolotny View Post
    Thank you
  1. Replies: 20
    Last Post: 03-25-2016, 10:02 AM
  2. Timing Chain Guide Parts List for the M60
    By Sansouci in forum 1988 - 1994 (E32)
    Last Post: 03-07-2016, 01:03 PM
  3. Lower timing chain guide part
    By SergeBMW in forum 1995 - 2001 (E38)
    Last Post: 01-30-2016, 10:03 PM
  4. Replies: 36
    Last Post: 04-18-2014, 11:37 PM
  5. M62 vanos timing chain guide replacement parts list
    By nighttowl in forum 1996 - 2003 (E39)
    Last Post: 11-01-2010, 04:37 PM
