Results 1 to 10 of 10
Thread: Auto up/down windows question/problem
    Jan 2017
    Romania
    e39 528i
    1993 520i touring
    I have electric front window, but there is a problem.
    Left and right work well on their own, left rising and lowering with the one touch function (the quick tap) and the right one has this function only on lowering.
    The problem is that when the left one is rising or lowering with one touch and i press the button for the right, they both stop. They both work at the same time, but only if i keep the buttons pressed.
    They will rise at the same time when i keep the key in closing position in the door lock.
    In short, they both lower at the same time using quick tap, but will not rise the same way.
    Seems like a electrical gremlin. PLS help
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    Pretty sure this is how the windows function? Touch anything during the auto roll up/down (another window, sunroof switch) and it cancels.
    Jul 2011
    Ann Arbor, Michigan
    1995 BMW 525i 5 speed
    Sounds normal to me
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Jan 2017
    Romania
    e39 528i
    Oh, i did not know that. Seems wierd to function like that in relation to newer cars like e39 for example, which will close both of the windows at the same time with the quick tap.
    THX guys
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Up requires more power. the GM has an internal overload relay, so there we are limited with the GM.
    The relay switches off
    when there is > 60 seconds more than 36A or
    when there is longer than 0.3 seconds between 36A and 60A (overload)
    when there is longer than 0.1 seconds >60A (short circuit)
    This internal relay inside the GM is additionally to the normal 30A fuse. The electronic fuse is reversible. Inside the GM the load of the RM is measured and in case that exceeds certain values, the reversible fuse will stop the action. The switch off values are set to less than the 30A fuse. So this 30A fuse will not melt. An automatic switch on comes after 60 seconds, however, only, if the power consumer was switched off or in case there is no short circuit detected. The lock is released by switching off terminal 15. A automatic switch on is possible 6 times with terminal 15 switched on. To reduce the Amps only max. 2 window switches can be operated at the same time. In case several window switches are pushed at the same time, only the first 2 pushed ones will operate. In case already with 2
    pushed switches the limit is reached, the system will switch off one switch. In such case the front door windows have priority.
    See under 10 ZKE German language function description of the GM http://www.e32-schrauber.de/bmw/s-zke.htm
    Virginia
    95 525, 93 M5, 05 X5 x2
    A bit off-topic but a window function question nonetheless. One of my windows has a clicking sound when it reaches the top and bottom. The window falls short of closing by about a quarter inch. Is this a limit switch problem or a gear slipping, or something else?
    Jan 2005
    Japan
    I assume the window regulator mechanism has a missing tooth or some more. You have to remove the door card to check, also check the 2 white slider clips and the rail they are sliding in.
    moroza's Avatar
    BFE
    E34T
    Quote Originally Posted by GregT53 View Post
    Is it a light relay-type click, or heavier? If you can readily hear it through the door card, I'll guess it's not the limit switch but a gear tooth or something else in the mechanism. The limit switch does not work as a true logic gate; closed, it still allows the window motor to move for up to a couple of seconds (open, there is no restriction).
    Virginia
    Easily heard through the door card. I'll have to remove the card and operate the window to determine what's going on. I reckon it's the motor.
  1. Window questions / problems
    By dannyrabahat in forum 1991 - 1999 (E36)
    Last Post: 04-08-2015, 09:49 PM
  2. Auto up/down windows
    By HDIDDY in forum 1995 - 2001 (E38)
    Last Post: 03-22-2015, 06:29 PM
  3. all auto up & down windows?
    By rideanddestroy in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-07-2011, 11:21 PM
  4. Auto up/down Windows to all windows.
    By tlamm in forum 1991 - 1999 (E36)
    Last Post: 08-25-2009, 08:20 AM
  5. Auto up/down window buttons
    By Papa316Smurf in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-28-2006, 06:16 PM
