Vargas Turbo N54 OE Plus Replacement Turbos In Stock
Shop Vargas Turbos for 335 Here
Vargas Turbo Technologies has been in business since 1979, offering rebuilt and re-engineered turbo solutions. With the N54, they identified a need for both cost-effective turbo replacements and proven turbo upgrades. The biggest complaint on N54 turbos is the rattle from the wastegates. The factory wastegates have actuator arms that lose their tension very easily, resulting in an annoying rattle. N54 wastegate rattle is the biggest complaint we hear from our customers. Vargas rebuilds each turbo assembly with OEM internals and replaces the actuator arm with a stainless steel arm of their own design. Because the Stage 1 uses stock BMW/Mitsubishi turbo housings, all of the stock turbo plumbing and intake hoses will match up. It's recommended that the rest of the system be upgraded to handle your tuning goals. The final Vargas rebuilt turbos are better than the factory rebuilds and at a lower cost!
Shop Vargas Turbo Install Kits Here
They've made it even easier for you to get your car back on the road and running right again with your new turbos. They've put together an install kit containing all the components you need to get your new turbos installed properly and efficiently. This means you can get your car back on the road faster and enjoy your new turbos!
Call or email us today! 800.280.6966 or info@turnermotorsport.com
Turner Motorsport
/ // Parts and Performance for BMWs
16 South Hunt Road
Amesbury, MA 01913
800-280-6966
