Results 1 to 12 of 12
Thread: Couple questions about 540i issues
    Aug 2018
    Walnut creek
    Ive been working on my 540 project car and run into some issues.. have a coolant leak that starts once the car is warmed up that drips on the top of front passenger side of the oil pan and then runs off the car. Is this the water pump gasket? I plan on replacing all the cooling system when money permits but for now I'm trying to pin point this to know what parts are absolutely necessary at this point. I plan on replacing the shroud at the same time. Car doesn't overheat, just leaks.
    Also when the car is first started it sometimes smokes...smells like gas and oil but it goes away it's not consistent what could this be? It sure needs a tune up but I'm more concerned about the smoke aspect could this be a pcv valve?
    Thirdly, the rubber hose line going from the oil filter on the driver side into what looks like a metal fitting into the motor, what is that called? so I can try to order it, mine broke away from the plastic nipple.
    Thanks for any help or advice in advance
    Dec 2013
    Chicagoland area
    EXOTICS
    Enter your vehicle VIN# here:https://www.realoem.com/bmw/select.do
    Then search the diagrams for part names and part#'s.
    Dec 2013
    Chicagoland area
    EXOTICS
    Btw, here is an excellent site for BMW OE,OEM parts:https://www.fcpeuro.com/BMW-parts/
    Best warranty + free shipping!
    JimLev's Avatar
    JimLev is online now Artifically Aspirated Moderator
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Could be the water pump or the expansion tank.
    Valve covers may be leaking oil on the exhaust manifold.
    The rubber hose on the oil filter canister is the drain hose for the canister filter. When you loosen the cap the oil drains out thru that hose and into the sump.
    Aug 2018
    Walnut creek
    Looks more likely to be water pump based on where it's landing. I'm assuming it's just the gasket since it doesn't over heat but since I'm gonna be in there it probably only makes sense to do the pump and test my fan and see if it needs replacement..probably thermostat as well.
    Especially since it only does it once warmed up It probably isn't the expansion tank I'm thinking it's once the thermo opens is when the fluid reaches the leak location.. thank you for that info on the drain hose I'll check fcpeuro for it since I didn't see it on rock auto.
    Thank you!
    Aug 2018
    Walnut creek
    Also the smoke is coming out of the tailpipe not off the manifold
    Sep 2013
    Tx.
    02 bmw 540
    That would be your CCV valve located behind the intake manifold near the firewall.
    JimLev's Avatar
    Sundance Mesa, NM
    Make sure you use a real BMW waterpump gasket. Many have used aftermarket gaskets and found that they don't last.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    IME a water pump leak looks more like spray all over the damn place because its right in the path of fan-air (even with a fan-delete) and it shows up more as the dried up white residue all around and is super hard to pin down. If you have that (white residue all over the front including hoses that are near the water pump) then yeah... WP. If its just pooling down on the upper oil pan... maybe alternator seal? Oops wait - NV motor, never mind.
    Valley pan? VP usually leaks tend to drain out more towards the back but some can leak out the front too if its really bad.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Aug 2018
    Walnut creek
    https://youtu.be/CcuciPGKcGI car makes this weird noise from the back of the car. Excuse the damage I'm bringing back a car that appears to have gone off road..
    Seems to have some kinda leak from this thing
    https://i.imgur.com/jI44OLb.jpg
    And this Lil bracket looking thing needs a home.
    https://i.imgur.com/fhZedyW.jpg
    Aug 2018
    Walnut creek
    Ahh I figure that thing is a tensioner..
    Mar 2010
    Pictures don't work brabrabrabrad...? Looks like you didnt give public permissions to them or something? Can't tell much from the vid...
    2003 M3CicM6 TiAg
    Former:
  1. First BMW, couple questions on 540i
    By thehig in forum 1996 - 2003 (E39)
    Last Post: 02-25-2015, 11:43 AM
  2. Replies: 14
    Last Post: 08-14-2014, 11:46 PM
  3. New 540i - Couple Questions
    By TommyV in forum 1996 - 2003 (E39)
    Last Post: 09-03-2007, 01:03 PM
  4. Couple questions regarding common issues :)
    By pozican in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-16-2007, 09:05 PM
  5. Couple of pre-purchase issues/questions
    By CO330xi in forum 1999 - 2006 (E46)
    Last Post: 02-08-2006, 01:01 PM
