RM European Auto Parts
Results 1 to 5 of 5
Thread: Door lock/unlock electric issue X5
    Jun 2018
    Gatineau
    BMW X5 2E53
    Unhappy Door lock/unlock electric issue X5
    For the past week or so, I can't unlock or lock the driver door either with the center console knob or the remote function of the key.
    I can unlock or lock it manually, inserting the key and turning left or right.
    By doing so, ALL the other doors either locks or unlocks.
    I looked into the shop manual for this and they mention a driver door module that control this function.
    First question : Where is this module located ??
    Second question : Is the module is within the door mecanism, If so, I can pinpoint the wiring and find out If the signals are getting to the locking/unlocking motors.
    PS: thanks for the reply
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    On your X5, the "door modules" are essentially enormous window switch units. As I recall, you can gently pry up the entire unit without removing the inner door panel, to access and test.
    Here are the wiring diagrams and service manuals for your vehicle:
    https://www.newtis.info/tisv2/a/en/
    Chris Powell
    BMWCCA 274412
    Feb 2009
    KC North, MO, USA
    1996 740iL
    My money is on the door actuator.
    Jun 2002
    E39M5, E500 4WD
    That's a high probability indeed, my friend. That said, I have a big warning bell for X5 door locking, having prescribed an actuator/latch one time, without testing for output from the door module. I KNOW, it's ALWAYS the actuator....except with X5's.
    I'd test for power on the black , and also the white wire, when triggering the lock/unlock....and then, as a double check, I'd deliver power from the car's B+ terminal to one of these wires, and see if it locks / unlocks. Check fuse 20 too.
    (I looked up an '02, because no date was given.) The screenshot will only be good for 14 days.
    https://screenshots.firefox.com/MW9f....prodemand.com
    Chris Powell
    BMWCCA 274412
    Jun 2018
    Gatineau
    BMW X5 2E53
    Hi guys and thanks for the info.
    I checked the fuse NO. 20 and it's in good shape, it is short on both terminals ( joke )
    I will run the ''feed test from the previous post and keep you posted as for the results.
    Thanks a million.
    PS, it's an X5 2005 (E53) with 3.0L.
  1. Interior door lock/unlock switch issue
    By beemer325i in forum 1999 - 2006 (E46)
    Last Post: 08-16-2013, 09:43 AM
  2. door locking/unlocking issues 1993 318i
    By njbmw in forum 1991 - 1999 (E36)
    Last Post: 12-21-2010, 12:25 AM
  3. strange door lock unlock issue
    By fixture in forum 1991 - 1999 (E36)
    Last Post: 05-10-2010, 04:21 PM
  4. Door lock/unlock issue
    By flyfishvt in forum 1991 - 1999 (E36)
    Last Post: 04-06-2010, 06:34 PM
  5. Door Lock/Unlock Issue.....
    By Shotgun Man in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-11-2006, 02:38 AM
