Recently replaced the clutch slave cylinder in my 94 325is and the car drove great for last couple weeks.
Parked it for a few days and went to drive it over the weekend but my clutch pedal had no tension.
The pedal would sink and not return when pressed. Could this be caused by air in the system or more likely because of a bad master clutch cylinder?
Thanks for any help and guidance,
MJ
Could be a faulty slave again.. me and a buddy install a new one this weekend and it failed within a day.. I would check there first. If it check out okay then check the cylinder it might not be building pressure.
