Have a SLS light and scanned it and it turned out being the rear right sensor. Replaced it and wiped codes and it still shows up. I suspect its a broken wire somewhere. Does any one have pictures or a diagram of where the sensor wires go from the plug?
I do not have a pic, but the wires go right up in to the rear cargo area. Should br able to see them from the top. Its common/possible the wires got knocked.
Is the sensor seated correctly with the little arm facing the right way? Believe it or not, there's a wrong way to install them (I've had that happen before).
1995 525i 5-speed - Thread
