Results 1 to 3 of 3
Thread: SLS Light - Rear Right Level Sensor
    Dec 2013
    Canada
    135i
    Have a SLS light and scanned it and it turned out being the rear right sensor. Replaced it and wiped codes and it still shows up. I suspect its a broken wire somewhere. Does any one have pictures or a diagram of where the sensor wires go from the plug?
    May 2018
    Florida
    '99 E39 M5T
    I do not have a pic, but the wires go right up in to the rear cargo area. Should br able to see them from the top. Its common/possible the wires got knocked.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Is the sensor seated correctly with the little arm facing the right way? Believe it or not, there's a wrong way to install them (I've had that happen before).
    1995 525i 5-speed - Thread
  1. Rear right speed sensor (1st code was 5F00, now showing 5E4A)
    By Mud in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-23-2018, 04:16 AM
  2. Replies: 0
    Last Post: 03-22-2018, 12:49 PM
  3. Rear headlight level sensor wiring mystery
    By davtex in forum 1996 - 2003 (E39)
    Last Post: 03-17-2018, 04:21 PM
  4. 328is check engine light and coolant level sensor
    By xiii0 in forum 1991 - 1999 (E36)
    Last Post: 04-29-2008, 01:01 PM
  5. Rear right ABS sensor wire is damaged. ABS light is OK. Cost?
    By Eurodude66 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-10-2006, 02:29 PM
