RM European Auto Parts
Results 1 to 3 of 3
Thread: Stoopid Noob question about adding automatic transmission fluid
    Jun 2018
    New England
    2004 325xi
    So, think I'm low on tranny fluid
    On the top of the engine bay, right side behind radiator is a cap that says "Use ATF Fluid only". The stick reads wicked low. Is that where I add the tranny fluid? I thought it was only accessed underneath?
    If that ISN'T the tranny fluid, what is it?... cuz that's the fluid I need.
    Thanks. This is a beater car I got cheap and use sparingly in the snow or when I need a back seat. I'm gonna drive it in to the ground. It's paid for itself, so I'm not doing anything fancy.
    Thanks.
    Seamus.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    That is the power steering fluid, and it uses Dexron III ATF. Note that the dipstick of the cap should only be wet about 3/4 an inch or so, when the cap is screwed on fully. If you overfill it, when the fluid gets hot and foams, it will come out of the hole in the cap.
    The transmission is filled from below, with engine running.
    Chris Powell
    BMWCCA 274412
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Transmission fluid level check info/trans service https://www.europeantransmissions.co...ansService.pdf
  1. 90 535i - Automatic - Transmission fluid questions
    By travbjork in forum 1988 - 1996 (E34)
    Last Post: 07-20-2011, 10:31 PM
  2. Yes/No Replacing Automatic Transmission Fluid?
    By SseeDragon in forum 1992 - 1999 M3 (E36)
    Last Post: 08-17-2006, 05:12 PM
  3. 323i 2000 replacing automatic transmission fluid?
    By mokaction in forum 2001 - 2006 M3 (E46)
    Last Post: 06-20-2005, 11:46 PM
  4. Changing Automatic Transmission fluid...
    By myred318i in forum 1996 - 2003 (E39)
    Last Post: 11-12-2003, 08:42 AM
  5. Pelican Parts Technical Article: Automatic Transmission Fluid / Filter Replacement...
    By Wayne@PelicanParts in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-27-2002, 02:00 AM
