Results 1 to 3 of 3
Thread: E90 Injector Tip Broken Off During Removal and Stuck
    Jun 2018
    KCMO
    ‘08 e90. ‘00 e39
    Car was dumping gas all of a sudden, pulled engine cover to diagnose leak as coming from rearmost injector. Pulled said injector, tip is broken off and remains in cylinder head. Any idea on best way to safely remove without it dropping into the cylinder?
    Fort Collins, Colorado
    2008 328xi Sportwagon
    Somebody will probably have a better idea, but I'll share one I thought up out of nowhere....
    What about rotating the engine until both valves are closed, remove the spark plug, use an adapter that lets you connect an air hose to the spark plug hole, and give it a sudden shot of 100PSI pressurized air? Should blow everything outwards.
    Jun 2018
    KCMO
    ‘08 e90. ‘00 e39
    That is a very probable solution that I like way better than going full Feck it mode and just plugging the high pressure line and cranking it hoping compression and that it would do it on its own 🤣
  1. Tips and tricks for removing broken exhaust studs?
    By sfgearhead in forum 1988 - 1996 (E34)
    Last Post: 10-17-2010, 08:15 PM
  2. removing injector tips
    By bmwlover0725 in forum 1983 - 1991 (E30)
    Last Post: 05-08-2009, 04:34 PM
  3. oil on tip os spark plug during removal?
    By dan8501 in forum 1991 - 1999 (E36)
    Last Post: 04-22-2009, 09:42 PM
  4. broken bleeder screw removal tips?
    By Bobby Bonko in forum 1983 - 1991 (E30)
    Last Post: 10-10-2008, 08:38 PM
  5. Injector Tip Broken, Plz Help
    By realw5 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-04-2005, 03:18 PM
