Results 1 to 21 of 21
Thread: Tie rods ends won't screw off
    Jan 2018
    Chicago
    01 540ia
    Question Tie rods ends won't screw off
    I've already popped the ball joint off but they absolutely won't budge when trying to unscrew them. All the tutorials I've seen make it seem easy to unscrew them, any tips? I've already doused them in wd-40 and pb blaster, they're trw tie rod ends from the last owner
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Check out the link below to one of our site's DIYs - hope this helps you troubleshoot.
    https://www.pelicanparts.com/BMW/tec...eplacement.htm
    888.280.7799 | 6am - 5pm PST
    San Jose, CA
    1997 BMW 540i 6 speed
    Not surprising, given where you live.
    You need a tool to spread the sleeve after loosening the clamp nut. It's a socket with a small square end that fits into to slot of the sleeve. Turning the socket spreads the sleeve.
    United States Of America
    997tt,850,02m5,w140 s500
    Quote Originally Posted by fedisrico View Post
    the problem is you live in chicago..
    also rust... & chicago rust is immune to wd40.
    its nasty, so if your going to be replacing the tie rods, i just used a bandsaw & cut them off.
    Jan 2017
    USA
    E21, E46
    Try pb blast. You can get it at any parts store. Let it soak in for awhile.
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    Are you attempting to remove at the inner joint (32” wrench) or the outer section? Having done this job recently I can tell you heat is the only way to loosen them. Hit them with some PB blaster and then take a torch to them in 30 sec intervals. They will loosen up with a wrench and a few bangs from a heavy mallet. I can’t be certain mine mine looked like they were frozen with red loctite on the threads. And they were definitely original.
    Jan 2018
    Chicago
    01 540ia
    Thanks guys, the inner ball joints were really loose so I decided to just order the centerlink instead of trying to unscrew them
    Dec 2012
    Philly Suburb
    2002 BMW 540iA
    If your car is 540i, were you able to loosen the pinch bolt?
    Jan 2018
    Chicago
    01 540ia
    Yeah, the pinch bolts came off pretty easy, they just wouldn’t twist, I had someone help me and we still couldn’t budge it, edjack pointed out you had to use another tool to spread it but I decided it’d be quicker and easier to express ship a new lemforder centerlink from fcpeuro.
    Quick question for anyone, would it be easier to remove the idler arm still attached to the center link and press it out when it’s off the car? I’m not replacing the Pittman or idler arm so I need to put them on the new centerlink
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    Several years ago I replaced the center link and outer tie rods at the same time (along with all the other steering parts). I removed the original assembly and put the new tie rods onto the new center link and matched the original dimensions as close as I could. When I had it all together the alignment was so close that I didn't even get it aligned right away. When I finally did, the guy said it wasn't even that far off.
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
    Dec 2012
    Philly Suburb
    2002 BMW 540iA
    Is the tie rod end ball joint still attached to the hub? With the ball joint still attached to the hub, you just need to twist center link, at least that was what I did few years ago.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Replace everything as they have lived their respective life
    https://www.fcpeuro.com/BMW-parts/54...001&m=20&e=188
    This complete refresh will save you from hunting down one loose part one after another, especially after getting just the tie ends replaced. Most posters who have just replaced one or two parts on the center steering link report that they now have shuttering on hard braking or other vibrations that they chase. They often gone down the "rotors out of round" path only to discover that an idler arm was the issue or the center link itself was the issue, etc.
    Save your brain and pain. E39 are hyper sensitive to suspension vibrations and replacing one new part in a system that has multiple parts allows the one old worn part to get all the stress and cause a rpm/ speed specific vibration.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    ^^^^ yes
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Jan 2018
    Chicago
    01 540ia
    Stephen, I'm putting it for sale right after I finish and get an alignment and oil change, 540's don't do too good in Chicago winters so I'm just doing enough to get it sellable
    May 2014
    Sadness...
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    In that case fix only the items that are safety related and kick it over the curb.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Jan 2018
    Chicago
    01 540ia
    UPDATE: The new lemforder centerlink came in today, but one of the inner tie rods was poking through the box when I received it. This ball joint is now very loose and moves around with no effort while the other one is very stiff and takes effort to move it even a little bit. There's no rips or grease leaking as i can tell but there is a sticky sound when I move the loose one.
    Is the ball joint damaged? I know they're supposed to move around but I'm not sure if it should be so lose before it's even on the car, especially since the other one is so stiff. I'd hate t have to return it and have my car in the garage for another week
    May 2014
    They should be fairly stiff it's new. Heck, I still have my car's origonal centerlink and tie rods in the garage. They had 120,000 miles on them when I replaced them and they are still stiff.
    CT
    E28, E32, E39, E53, E90
    I refreshed my entire front suspension a few years back and the difference was amazing. The steering feels tight and stiff again, like a totally different car
    Jan 2018
    Chicago
    01 540ia
    Anyone else have easy to move balljoints?
    Dec 2012
    Philly Suburb
    2002 BMW 540iA
    Balljoint should be stiff, that one is no good, better return it and exchange another one.
  1. tie rod end won't FIT!
    By Sweeeems in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-17-2006, 05:32 PM
  2. tie rod end won't FIT!
    By Sweeeems in forum 1991 - 1999 (E36)
    Last Post: 12-16-2006, 07:18 PM
  3. Tie rod end blew up! NEED HELP!
    By NegativeCambre in forum 1991 - 1999 (E36)
    Last Post: 06-16-2003, 08:07 PM
  4. Tie rod end or whole assembly?
    By Jack T. in forum 1991 - 1999 (E36)
    Last Post: 04-23-2003, 12:16 PM
  5. Tie rod ends or whole assembly easier?
    By M Rob in forum 1992 - 1999 M3 (E36)
    Last Post: 04-02-2003, 10:44 AM
