Results 1 to 5 of 5
Thread: Rear Discs/Rotors stuck because of handbrake shoes!
    Jan 2016
    Aberdeenshire
    1991 BMW E34 525i
    Any idea how best to remove my rear rotors? They were completely seized to the hubs but I've freed them now (some lateral movement), but they are still being held by the handbrake shoes (handbrake is 'off').
    The rotors/pads need replacing anyway, and I'm sure the shoes are also, so I don't mind ruining them on removal. But I don't want to break anything that can't easily/cheaply be replaced.
    Obviously I can't adjust the handbrake because I can't rotate the rear wheels to get a screwdriver in (which is why I'm trying to take it apart anyway, I tried to use the car for the first time in a few months and realised the rears were stuck). The rears rotate a degree or so (just the movement of the shoes I guess), but they are pretty well stuck, and I assume there is a groove formed somewhere which isn't helping get them off.
    Albuquerque, NM
    way too many
    With the wheel off, tap the perimeter of the drum portion with a hammer in numerous places, then put the wheel back on and drive the car forward or backwards to see if it will break loose. If not, repeat, pounding the drum harder.
    Here's some details on adjusting the shoes:
    http://www.bimmernut.com/forum/showt...Handbrakes-101
    ​"The US Olympics bobsled team has renamed their sled 'Biden' because nothing has taken America downhill faster"
    TheStigg (aka "gale")
    92 735i 5-spd, turbo pending
    89 535i 5-spd (may she rest in pieces)
    94 325ic 5-spd
    87 325is
    Jan 2016
    Aberdeenshire
    1991 BMW E34 525i
    Yeah I was scared I was gonna burn the clutch out tbh when I tried moving it before
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Don't tear them off, because the weak point is the backing plate, which can't be replaced without pulling the hub, which usually means replacing the wheelbearing.
    Try hosing down the whole shoes assembly with penetrating oil through a thin straw. Let it soak a good bit, then stick two sacrificable wheel bolts in the hub, preload with a nice rigid bar, and give it a good smack.
    If all else fails, cut the rotors up with a cutting wheel, just beware of the hubs.
    NW suburban Chicago
    hiss by my window
    A couple of thoughts from the rust belt. You mention that you cannot turn the rotor. Was the wheel seized? Perhaps with some leverage, such as a long bar between a couple of wheel bolts screwed in it will turn and you could back off the shoes.
    Is there access to cut/grind/break the heads off of the brake shoe retaining pins?
    Penetrating oil around the wheel bolt holes may work it's way to the hub area.
    Good luck
  1. Aargh. Can't fit new rear rotor over new parking brake shoes
    By sienayr in forum 1983 - 1991 (E30)
    Last Post: 05-02-2016, 10:33 AM
  2. E34 E34 New Balo Rear Brake Rotor Discs - $30
    By edgedude in forum Brake Kits, Rotors & Pads
    Last Post: 04-21-2013, 05:45 AM
  3. FS: E39 528 Rear Disc Rotor Drilled & Slotted
    By kishman in forum 1996 - 2003 (E39)
    Last Post: 03-18-2010, 09:12 PM
  4. DYI mess how to remove rear disc rotor
    By Bahamas Bimmer in forum 1991 - 1999 (E36)
    Last Post: 08-09-2009, 09:27 PM
  5. E36 Rear Brake Disc/Pads/Handbrake Shoes
    By Stevis2007 in forum 1991 - 1999 (E36)
    Last Post: 02-05-2008, 08:47 AM
