Can't find this anywhere. My 'rents have an 02 firebird TA WS6, and have an extra set of WS6 wheels (one set ended up with a cracked wheel that I'm getting repaired).
Wheel specs:
17x9
ET50
hub 70.3
I would run a ~15-20mm spacer, turned down to the 70.3 hub.
Here's the wheel I'm talking about, specific to the 2002 WS6 transam.
Can’t you just get the centers bored out ? Then you could run a spacer . Or just sell those to a GM person and #Profit ?
http://www.bmwmregistry.com/detail.php?id=13792
* E39 M5 SterlingGray -RIP 11/2018
* E36 328 vert Schwarz - ~TurboProject underway
* E90 335i Sedan MonocoBlau - Daily ToddlerTaxi
You will need a spacer with that offset and the fronts will be a bitch to fit without a good bit of camber
98 M3 sedan
Interesting. Spacers will address the offset. Hub adaption could be part of custom spacers or you could bore the hubs. What do the wheels weigh?
Yep, plan would be to adjust the hub bore in the spacer. - and spacer would of course fix the offset problem. The wheels are worth too much to machine them.
...and they're 19lbs from my reading :o not sure if I believe it...I'll have to measure.
I honestly just want a unique wheel for my vert, have always loved these since they came on my mom's, and want a strong 5 spoke (sold some borbet type E wheels and miss them, they're very similar).
You should be able to use these with a 70.3 spacer https://rover.ebay.com/rover/0/0/0?m...2F272724831579
98 M3 sedan
These go the wrong way (allow BMW wheels to fit GM stuff).
I need something like this, only from 72.56 to 70.3 (luckily I have friends with lathe...).
https://www.ecstuning.com/b-h-and-r-...iABEgIV2vD_BwE
Seems like you could buy better looking wheels that actually fit for the same money as custom adapters and spacers.
you are probably very correct, however I have these (sorta) already. And...I think I have at least one pair of spacer lying around that I could turn.
...And I've been looking for a 'strong' 5 spoke...and in BFE Illinois there aren't a lot of options. Car already has Rondel #58's, so they are a good backup.
19 lbs is light for a factory 17x9!
