RM European Auto Parts
Results 1 to 5 of 5
Thread: E36 no power when warm
    Oct 2018
    Liverpool UK
    BMW E36 323i
    Hello. Read hundreds of posts about similar problem but can't find answer.
    Bought this E36 323i like month ago. There was a big oil leak in valve cover so oil was going in two spark plugs. Fixed that. One day engine was running and then suddenly stalls. Diagnostic said there is problem with crank sensor so I changed that. Car was running fine for about 30mil and the started to loose power up to 3k rpm so now when car is cold it's running perfect when temperature goes above blue it's starts to loose power. The feeling is like there is not enough fuel or all sparkplugs is not working. Have changed air mass sensor and cam sensor still same thing.
    Maybe someone can help me find answer.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I’d check the fuel pressure first. BMW fuel pumps seem to last about 5000 hours. There should be a test valve on the fuel rail. The pressure needs to be at least 50psi at all engine speeds.
    Oct 2018
    Liverpool UK
    BMW E36 323i
    Could it be like when the fuel pump warms up it starts to work bad?
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    Quote Originally Posted by NoGoe36 View Post
    Could be that yeah. Anyway you should follow the procedure given by Marcozandrini to make sure. Or if you don't want to and have access to a used pump (scrapyard or else), you could swap it with yours and see how it goes. If it doesn't fix the issue you put yours back in and save your money.
    Also, have you replaced the fuel filter?
    "If you have integrity, nothing else matters. If you don't have integrity, nothing else matters." Alan K. Simpson.
    5spd E46 "3XX": 328i engine, 330i Intake and exhaust, CAI, 323i diff.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Why did you change the cam sensor and the MAF ? Did you have codes that said they were bad?
    I highly recommend that you start by reading the codes with a good BMW specific scan tool. Don't throw parts until you know what parts to throw.
    While you're looking at the codes with that BMW diagnostic tool, have a careful look at the engine coolant temp sensor's live data, and that for intake air temp. See whether these two values correspond with reality.
    If the computer is seeing coolant temp or intake air temp of -40 degrees (an open circuit), the engine will run like crap as soon as it's warm.
    Chris Powell
    BMWCCA 274412
  1. e36 no power when warm
    By eroomtc in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-04-2011, 07:14 PM
  2. E36 WTB E36 Center Power Window Switch
    By haninja in forum BMW Parts Wanted
    Last Post: 05-30-2011, 11:10 AM
  3. E36 E36 Sedan power window motors
    By kenndoggy in forum Interior Lighting & Body Parts
    Last Post: 05-19-2011, 12:34 PM
  4. E36 Bmw e36 m3 power steering pump
    By ltimport in forum Suspensions, Springs & Shocks
    Last Post: 12-12-2010, 09:02 PM
  5. E36 E36 M3 Power Steering Pump and pulley
    By das borgen in forum Engines, Performance Parts & Software
    Last Post: 05-15-2010, 10:47 PM
