RM European Auto Parts
Results 1 to 7 of 7
Thread: 153 CAN engine load signal code
    Apr 2013
    Woodland Washington
    1996 BMW 328
    Hello there so I got my engine running better but this entire time I also have the code mentioned above in my transmission and my transmission seems to be in limp mode or a state similar to limp mode and I have no idea how to figure out why so does anyone know what causes of this code to pop up any help would be much appreciated
    Jul 2004
    Houston, TX
    36 Cylinders
    Is the transmission module original to car? What about engine computer (DME)?
    If not, what part number is it?
    Also, any corrosion on the can wires of the transmission computer/dme?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Personally, I suspect a bad signal from the MAF (yes, the mass airflow sensor for the engine). The DME needs airflow data to calculate load, and give that data to the EGS (transmission). A '96 car is very poor at telling us all the needed correlations, but that's my wild-assed guess.
    If you decide you need a MAF, make absolutely sure that you buy a OEM part, not some crap from Autozoo.
    Do you have and codes in the DME or the ABS computers?
    Chris Powell
    BMWCCA 274412
    Jul 2004
    Houston, TX
    36 Cylinders
    That's a good point.
    What DME codes are there?
    -Abel
    Apr 2013
    Woodland Washington
    1996 BMW 328
    Okay so my transmission control module with the same engine control modules possibly different but that would have been changed a couple of years ago and the codes there are a couple for the engine which I'm working on right now which are a mixture deviation and a misfire and on the abs it's a transmission not coded or improperly coded I can't remember which
    Jun 2002
    E39M5, E500 4WD
    Please know that 328 Power 04 and I are absolutely on the same page. He is, absolutely, the best BMW computer guy I know. And I'm a fairly decent BMW tech, on a good day, anyway..
    And now you've added a mixture code...
    Any good BMW specific scan tool, plus a round 20-pin diag plug for your underhood connector, should give the info we need to make a reliable diagnosis, more than likely.
    Chris Powell
    BMWCCA 274412
    Apr 2013
    Woodland Washington
    1996 BMW 328
    So specifically the codes that I do have is mixture deviation cylinder 4 through 6 and misfire on cylinder 1
  1. Need Help. "Check Engine" light: 1215 Code
    By phillyB///M3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-22-2004, 01:54 AM
  2. CODE 147 can engine torque signAl
    By BMR2NV in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-06-2004, 09:56 PM
  3. CODE 147 CAN Engine Torque Signal
    By BMR2NV in forum Forced Induction
    Last Post: 08-05-2004, 11:40 PM
  4. Check Engine Light...ODB2 code (P0420)???
    By ///M3Turbo in forum 1992 - 1999 M3 (E36)
    Last Post: 04-05-2004, 10:43 AM
  5. Engine and transmission codes
    By surfdwn in forum 1988 - 1996 (E34)
    Last Post: 03-03-2004, 03:41 PM
