Results 1 to 4 of 4
Thread: 07/98 750iL - Double Temperature Switch - What does it feed?
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    07/98 750iL
    Issue: Interior dummy gauge is not reading. Cluster test makes it "move". The heads up will display the temperature with cluster cracked.
    Yesterday, I replaced the temp sensor in the top of the intake. No change. I'd thought there was only that sensor
    and one on the thermostat. There is a 3rd on the radiator itself.
    My question is, which one feeds the dummy gauge?
    It's # 6 in the diagram.
    Double temperature switch 91/104CEL
    https://www.realoem.com/bmw/enUS/sho...diagId=17_0105
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
    IL
    2000 740i sport
    Cluster test makes it move all the way to the end? Have a spare cluster you can program and test? I had one that someone failed a pixel repair that would even go up a qtr of the way and cluster would almost make it to the end but not fully. Had to have the motor replaced in it and its back to normal now...
    Sent from my SM-N960U using Tapatalk
    Mar 2011
    Greenville, NC
    Quote Originally Posted by purplecty View Post
    Yeah, cluster is good.
    2001
    Mar 2011
    Greenville, NC
    Timm mentioned in a post of yours I just found that it came from the T-stat itself on the V8. Id assume the V12 would be the same, but trying to verify before getting into replacing that. I have a spare from a previous 750 I had, luckily should it be that one.
    https://www.bimmerforums.com/forum/s...ing-on-cluster
    2001
  1. Help Installing Double Temperature Switch
    By 540-S3 in forum 1996 - 2003 (E39)
    Last Post: 09-10-2020, 09:32 PM
  2. M30 Double Temperature Switch plug
    By Strictlyapathy in forum 1988 - 1994 (E32)
    Last Post: 03-09-2011, 11:59 AM
  3. 1991 E34 535i what does the double temperature switch do?
    By yorkermiles in forum 1988 - 1996 (E34)
    Last Post: 09-30-2010, 02:43 PM
  4. Double Temperature Switch?
    By Z-Thrizzle in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-16-2010, 04:51 PM
  5. Coolant leak from "Double Temperature Switch"
    By 01sport in forum 1995 - 2001 (E38)
    Last Post: 09-19-2009, 02:48 PM
