Results 1 to 9 of 9
Thread: 2000 BMCW Z3 2.5 CAirbag Light!
    Aug 2015
    Savannah, GA
    2000 BMW Z3
    My apologies in advance! I know this has probably been talked to death before, but, the more I read the more confused I get! Need help for my Z3 roadster 2.5 ABS light! I bought a B800 and it indicated table 38, code 14 left side airbag sensor. I ponied up the cash and replaced it. My B800 now says Table 38, with the following codes 03,14,FO, 14,02,16,16,- -! I suspect that this car may have had a wreck although car fax does not show one. I have had both seats out and checked all connections and everything looked good. Needless the say, the B800 will not clear the codes. Should I send in the air bag control module for a reset? Any suggestions would be greatly appreciated! Sensors for this little critter are expensive!
    Jul 2004
    Houston, TX
    36 Cylinders
    F0 = Internal Error
    https://www.bimmerforums.com/forum/s...ly-found-a-fix!
    Which exact sensor did you replace and what part number did it have? Used or new?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2015
    Savannah, GA
    2000 BMW Z3
    It was the left side airbag sensor, P/N 65776905454. It was a new part.
    Aug 2017
    That's crazy, next time go to eBay. I had a defective side airbag sensor passenger side, put a used one in it for 35$ and it works.
    Aug 2015
    Savannah, GA
    2000 BMW Z3
    I guess that the F0 code is the death bell. I know of a place that resets the codes and all for 50 bucks, so I guess that is the next step. Thanks!
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Do some more searching and asking on this site before spending money. ..... You need a way to clear codes. You can download and use INPA if you are willing: http://www.bimmerforums.com/forum/sh...xperimentation ...... Or you can buy a tool for under $30. Sorry, I can't find it at the moment. Maybe someone else will chime in. .... Found it! I don't know it, but it was recommended on this site: https://www.ebay.com/itm/16223391199...rue&rmvSB=true Also, read this: https://www.bimmerforums.com/forum/s...ly-found-a-fix! .... and this might help also: https://www.bimmerforums.com/forum/s...=seat+tilt+mod
    Oct 2013
    Augusta, GA
    1999 Z3 M-Roadster, 2007
    Abel (328 Power 04) gave you the definitive answer to your problem in post #2. Follow the link he provided and then follow his recommendations.
    Aug 2015
    Savannah, GA
    2000 BMW Z3
    Are you still doing resets?
    Jul 2004
    Houston, TX
    36 Cylinders
    I can, as best as my time allows.
    -Abel
  1. Z3 E36/7 FS: 2000 BMW Z3 Face Lift Tail Lights $100 !!
    By z3roadst in forum Z3,Z4,Z8 Classifieds
    Last Post: 02-23-2018, 04:48 PM
  2. Z3 E36/7 FS: 2000 BMW Z3 Trunk Lid w/ 3rd brake light
    Last Post: 02-22-2018, 11:22 PM
  3. 2000 BMW Z3 Auto Tranny and SES light
    By Jhurt in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-14-2015, 03:15 PM
  4. 2000 BMW Z3- Check Engine Light is on
    By legenesepimp in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-13-2010, 09:12 PM
  5. 2000 Z3 Service Engine soon light
    By k9team3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-14-2009, 11:25 PM
