RM European Auto Parts
Results 1 to 2 of 2
Thread: I'm at a loss
    Oct 2018
    Evansville, IN
    1986 BMW 325
    I'm at a loss
    So, I have a 1986 325. The issue I've been having is that the car wants to sputter and choke, attempting to shudder and die upon acceleration until it hits about 2500 to 3000 rpms, at which point it catches power but I can still feel it not running at full capacity. It also tries to idle around 500 rpms and wants to die just while sitting. I've replaced the fuel pump relay after reading a few other threads, but the problem persists. Any ideas?
    New York
    1974 2002, 2009 128i
    First thing I'd look for is a vacuum leak. Lots of old rubber plumbing in there. A smoke test will be the most efficient way of doing this, but the M20 is not as packed in there as more modern motors, so you may be able to find it without.
    Failing that, test fuel flow and pressure per Bentley (you do have a Bentley manual, right?). I can't recall if the M20 has a cold start injector like the early M30s did; if it does, pull it out and see if it's leaking.
    There are other possibilities, but let's eliminate the basics first.
    Life's tough. It's tougher when you're stupid.
    -John Wayne
  1. electrical power loss
    By ganicki in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-27-2006, 01:43 PM
  2. 98 degrees, 90% humidity, gained tq and loss a
    By TKM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-06-2001, 01:45 AM
  3. 98 degrees, 90% humidity, gained tq and loss a
    By TKM3 in forum 1991 - 1999 (E36)
  4. a win and and a loss at the same time!
    By toofast4U in forum Kill Stories
    Last Post: 08-31-2001, 09:55 PM
  5. 95 M3 vs Supra (BIG LOSS!)
    By ArcticSilver in forum Kill Stories
    Last Post: 08-31-2001, 02:58 PM
