2010 550i.
One minute everything fine. Next minute sos failure on the SCREEN, I’ve lost Bluetooth functionality and no satellite functionality. Mac works, chimes work, and regular radio works.
You tube’d the topic. Bought the optic fiber loops and started chasing the chain.i have signal into sat module nothing out.
But my question ultimately is with the “loop” in place why am I still getting the SOS malfunction and nothing changes. I get that no satellite stations if module is bad, but wondering why no Bluetooth capability and sos inop still?
Are this inop functions somehow “wired through” the satellite module or am I actually chasing 2 separate module failures?
Thank you for anyone taking the time to chime in on this.
Those functions are not associated with the SDARS module. It is possible you have two failures. Does your satellite radio work if you bypass the TCU?
I don’t think I tested that far. I convinced myself that satellite module was the problem. I will test further
Can you help me with the tcu location? Is it the long rectangular module that is at the same location as the satellite module? On the rear drivers side inner fender? 2010 550i
Are you sure you are looping out the correct module
That’s the thing. I have the red optic light going into the sat module. But nothing coming out of the module . When I loop the sat module the. I get signal into the tcu module?
