RM European Auto Parts
Results 1 to 2 of 2
Thread: e39 heat/ac fan turns off randomly
    Oct 2018
    Ramstein Germany
    2002 520i BMW
    Recently my 2002 520i has been dealing with the issue of my fan wanting to turn off. This car has the e39 heater control panel 6916655 installed which makes it a little unique. Early in the morning I normally have no issues but later in the day it won’t stay on for more than a few seconds. I just replaced the fan and the resistor. This car does not have a fuse that covers the fan. Should I drop $100 on a new switch or get a new battery or resistor again? What do you guys think?
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Did you buy an OEM final stage resistor, or a cheap Chinese thing? The Chinese ones are often bad, right out of the box.
    You certainly DO have fuses for this: If I picked the right wiring diagram, those are # 46 and #76. However, if the fan works sometimes, the fuse is a very unlikely culprit, and the Final Stage Resistor is most likely.
    Here are your wiring diagrams, etc:
    https://www.newtis.info/tisv2/a/en/
    Chris Powell
    BMWCCA 274412
  1. 05 X5 heat/ac fan question
    By Getnany in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-25-2014, 04:30 PM
  2. heat/ac fan only works for 15 min
    By thebmwnut in forum 1996 - 2003 (E39)
    Last Post: 01-11-2011, 07:30 PM
  3. heating/AC/fan rocker control question
    By vbf in forum 1996 - 2003 (E39)
    Last Post: 03-22-2010, 05:11 PM
  4. Intermittent Heat/AC Fan - '99 328iC
    By mikel318ti in forum 1991 - 1999 (E36)
    Last Post: 01-10-2004, 07:00 PM
  5. Heat/AC fan ?
    By Strapp in forum 1991 - 1999 (E36)
    Last Post: 03-12-2002, 01:34 PM
