Results 1 to 9 of 9
Thread: Brake fluid always down around min mark...
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    I keep filling the brake fluid only to have it quickly return just above the min mark... but never any lower. I see what I presume to be an overflow hose (blue, fabric wrapped) on the reservoir but its plumbed in way lower that Id expect it- about halfway bt min and max. I can easily see how the level would end up where it is. Can someone school me as to its function? Might i be missing a check valve or ?
    Central Valley, CA
    '89 325iC
    Clutch line. Check your clutch master cylinder behind your clutch pedal. It may be leaking.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Yep, there's a leak somewhere in the clutch system. That blue hose runs to the clutch master which sits at the top of the clutch pedal. From there it comes back out via a hard line down the firewall. Next is a soft line to the slave cylinder on the transmission. The slave is the end of the line.
    Be aware you can't get the same blue hose anymore. The replacement is gray colored.
    "Howdy, Folks!"
    Jul 2013
    CT
    Thanks fellas. Clutch master is viewed from the passenger compartment yes? Where is hard line that goes thru the firewall best seen?
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Master is in passenger compartment. The rest is best seen from underneath the car.
    "Howdy, Folks!"
    Jul 2013
    CT
    Appears the master is leaking from the top. I see dampness above the fluid line connection.
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Master is the PITA one. I'd recommend replacing soft line and slave at same time.
    "Howdy, Folks!"
    Jul 2013
    CT
    I ordered master soft line nipple and grommet but not slave. Can the hard line at the back of the master not be unfastened at the master instead of at the fire wall?
    Jul 2013
    CT
    Not sure if this is common practice but I found it possible to pull the hard line into the cabin fat enough to dis/reconnect it to the master without working under the car.
    Mess on the carpet is from the prior leak not the removal/replacement.
  1. Brake Fluid leaking down clutch pedal onto the floor
    By trackbball21 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-15-2010, 10:18 AM
  2. Brake fluid light around redline
    By spkshasha in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-18-2008, 05:24 PM
  3. Brake fluid Resevoir: always some fluid on top after each session
    By Dinanify in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-17-2006, 09:37 AM
  4. Which brake fluid?
    By C///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-22-2001, 02:22 PM
  5. How often should I change brake fluids?
    By JT-KGY in forum 1992 - 1999 M3 (E36)
    Last Post: 04-05-2001, 05:52 PM
