Looking for a fuse or relay for the starter my car wont start battery is good and before replacing the the starter it removing want to know if there is a fuse or relay I have found the compartment in the trunk the one in glove compartment but dnt know which one it is if any...
Do you still have the fuse index on the laminated sheet located on the rear fuse box? (see pic below)
And if you're not familiar with the online BMW TIS...here's a link: https://www.newtis.info/tisv2/a/en/ . Type in the last 7 digits of your VIN (or make the correct model selection) then type "starter" into the search box. You'll see a list of results that have links to DIYs and wiring diagrams/pin-outs/etc that are associated with "starter".
Good luck.
