Results 1 to 10 of 10
Thread: Today was a good day
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    Pick n pull treasures.
    Sent from my LGLS755 using Tapatalk
    Apr 2014
    cincinnati
    1986 bmw 735i
    What is it ....details ?
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    265/6 5 speed. I also grabbed the slave cylinder, flywheel and clutch( both looked new). I got the pedals and master cylinder but they look like they won't work so I am taking them back.
    ATL
    e23 e36 e46
    What car is it from? If e23, grab the driveshaft and cross member.
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    I wish. It was a "85 535i euro. I did get the cross member, it looks like the online pictures of the e23 one, are they that different? I know it is going to be a long search for all the parts I need. I need some pedals, a driveshaft, and the correct master cylinder to start with.
    I do have a e23 shift plate and linkage rod headed to the house.
    ATL
    e23 e36 e46
    Quote Originally Posted by motohunter4 View Post
    I had a couple of spare driveshafts that I have since sold over the years. I think i still have s shifter plate or two. Not sure about the crossmember, but one could be fabbed easily enough if necessary.
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    Does anyone know the distance from the transmission mount hole to the outer hole?
    Oct 2007
    Valley Village, CA
    1985 745i
    When I swapped mine to a g265, the dealer was able to get the cross member for me. New from Germany was around $50 IIRC. Check realoem for part numbers.
    A 3-speed auto driveshaft will fit. Some say it’s not long enough, but I’ve been running mine for 6+ years without an issue.
    When your enemy is making a mistake, do not interrupt him.
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    I found a 3 speed automatic driveshaft. I am going to order the crossmember if it's still available.
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    I got the crossmember in today. The holes for the rubber mounts were closer together than the E28 ones, which had me worried. I measured the transmission and it looks like it's not an issue.
  1. Today was a good day...Nurburgring pics inside
    By ///Maniak in forum BMW Rides & Events
    Last Post: 06-13-2005, 12:14 AM
  2. today was a good day
    By 12:03 in forum BMW Rides & Events
    Last Post: 05-03-2004, 12:44 PM
