Results 1 to 3 of 3
    Mar 2013
    Alpharetta
    1998 z3
    Is my new waterpump bad?
    Fighting overheating. Replaced Waterpump, thermostat, reservoir, radiator, fan clutch and getting boiling in the reservoir. Have done basic block test and not thinking it’s a head gasket.
    After following bleeding instructions (more than once, believe me) I still get air bubbles, loss of coolant, what sounds like boiling coolant in the tank. This is after 10-15 mins of driving. Doesn’t overheat but don’t go to far either.
    I ran it with the overflow cap off and some of the bubbling subsided but the coolant seemed to be sort of pulsing rather than a smooth circulation I think I should be seeing.
    Aftermarket Waterpump, bad out of the box maybe? (Not leaking)
    Sent from my iPad using Tapatalk
    Jan 2016
    Ca
    2001 525it
    You won't think so. Is the heater set to hot to bleed the air out of there. Because of the different levels within the coolant system, on the e34's for instance some folks would raise the front end a bit to bleed them. Also after bleeding you can let the car sit for a few hours, with the hood up, to cool down quicker and if there are air bubbles the system might burp it self
    Mar 2013
    Alpharetta
    1998 z3
    Thanks, yes. Always bleed it nose up and I have a nice tilt on my drive. Heats always on full. Even runthe aux Waterpump to purge any air.
    Bought a Gates brand Waterpump, installation simple. Just seems like I’m getting cavatation.
    Also, test drives indicate mid 90’s coolant temps.
    Grasping at straws....
  1. New Waterpump...Is it Bad?
    By BMW2k10 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-18-2018, 01:39 PM
  2. let's talk about this rumor: new brake bads with new rotors=bad?
    By 1995red318i in forum 1991 - 1999 (E36)
    Last Post: 10-13-2004, 05:53 PM
  3. need new waterpump, does bmw sell metal propellors?
    By ReVsHoT in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-28-2004, 08:37 AM
  4. new radio, bad reception
    By harryu in forum 1991 - 1999 (E36)
    Last Post: 02-28-2004, 11:37 AM
  5. Just Got My New Car.. Bad Ass!!!
    By playinJ30 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-08-2001, 07:46 AM
