Results 1 to 3 of 3
Thread: Rear trailing arm bushings enough to correct camber.
    Nov 2017
    Grand Haven, MI
    1990 535i 428k miles
    My E34 has worn out trailing arm bushings and it's wearing through the rear tires. I want to fix this before I purchase new tires. However the car is on H&R Lowering springs (about 3/4") and i don't know if new bushings will correct it enough. I was thinking about getting power flex Urethane bushings, or the k-mac equivalent. But I don't know if I want or need that just to fix camber. Garagistic also has a weld on kit which is also an option because I do have access to a welder.
    But my main question is will my camber be fixed with new oem rear trailing arm bushings?
    Moderator and Owner of the Subreddit r/E34
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Feedback from someone who's had H&R long enough to notice tire wear would be best, but here's my $.02: the stock RTABs don't seem to sag much that I've seen, they just get stiff and cracked and occasionally get loose. I've noticed uneven rear tire wear with healthy RTABs and tall 530iT stock rear springs (granted, carrying some cargo). If you're in there anyway, install the weld-on eccentric bolt kit just to have that option regardless of whether the bushings are enough or not. The only downside is a bit more expense, and now you have to get the rear aligned as well as the front. But if you're paying for a front alignment anyway, upgrading to four-wheel job is usually a pretty low surcharge.
    Nov 2017
    Grand Haven, MI
    Well I just looked and apparently I have k-max eccentric bushings so that's why my cambers so high. PO must've installed them.
  1. Replies: 16
    Last Post: 01-17-2009, 06:24 PM
  2. AA rear trailing arm bushings, to hell and back
    By frayed in forum 1992 - 1999 M3 (E36)
    Last Post: 10-31-2006, 08:09 PM
  3. 95 and 97 M3 have different Rear Trailing Arm Bushings?
    By ///Arman in forum 1992 - 1999 M3 (E36)
    Last Post: 08-29-2002, 11:24 AM
  4. AA Rear Trailing arm bushings, noisey?
    By BMWM3some in forum 1992 - 1999 M3 (E36)
    Last Post: 08-23-2002, 08:35 PM
  5. Tech alert. Rear trailing arm bushings.
    Last Post: 07-05-2001, 08:47 PM
