Results 1 to 11 of 11
Thread: Weird electrical problem - windows + wiper - solved
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Have a weird electrical problem with my car. All windows and the wipers will stop functioning roughly 10 minutes into a drive. Car needs to be shut down for at least half an hour before they start working again. Heat might be a factor because if I park in a hot environment or on a hot day, they don't work from the start. This behaviour has been consistent for months.
    Have checked the fuses they are good. Changed general and relay module, no effect. Changed wiper stalk, no change. Exact same behaviour. Might be a wiring issue, something frayed somewhere. Dread checking on that. But anyone know where to start or what could actually be wrong, would help narrow down. Thanks.
    Alan
    Oct 2008
    Kettering,OH
    e34 535i and 98 528i
    It is the fusible link. I bet your seats do not work either. It is in located near the battery under the rear seat. Look it up and you will get a good pic.
    Andy
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Check the fusible link which goes from battery + pole inline to the fuse box under rear seat driver side. I assume the fusible link has a hair crack which works sometimes depending on temperature.
    Typical Failure syndromes:
    • Intermittent simultaneous falure of wipers, sunroof, windows, central locking, radio...
    • No power, like if the battery was dead
    http://www.bmwe34.net/E34main/Mainte...sible_link.jpg
    first 2 pics os the fusible link which goes to engine bay e-box, 3rd pic is the fusible link for the rear fuse box, and that controls all the stuff which is not working on yr car via the GM http://www.bimmerboard.com/forums/posts/377728/
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Oh if it was only as simple as that! But please question I have never had any current cut off issues in any form intermittent or otherwise that had, anything to do with the fusible link. Can it still be responsible for this issue?
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Oh if it was only as simple as that then there is a godt!
    But please a question I have never had any current cut off issues in any form intermittent or otherwise that had, anything to do with the fusible link. Can it still be responsible for this issue?
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Quote Originally Posted by alang1990 View Post
    Yes you have; the issues you describe are current being cut off. In this case (probably) because of hairline cracks in the fusible links. Common E34 problem, cheap and easy to fix.
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Quote Originally Posted by shogun View Post
    So there is a SECOND fusible link, that ONLY controls GM related stuff? I didn't know that. That makes a lot of sense. It is a current cut off as moroza point out. I'll check that along with my driveline later asap. Thanks !!
    Jan 2005
    Japan
    Yes, there are TWO!
    This fusible link B controls all stuff = central chassis electronics including the GM under the rear seat. But check it in detail, the cracks are often difficult to find, sometimes under the bolts/rivets.
    Pics and explanations are on my website in a pdf file.
    When you have probs with the engine: The other one = fusible link A goes to the engine bay , fusible Link A can also go intermittent and kill power to the the DME box. You can conveniently check this at your D100 Diagnostic Connector, pin 14. The voltage should be 12V at all times. If it is low when cranking, then Fusible A is your problem.
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    Well well. Another day and another good morning for the old warhorse. No make that a great morning.
    Here's why :
    The problem was the fusible link, but not link B which controls the cabin electricals. It was Link A which is supposed to kill the car itself if damaged. Apparently the fuse B for link B is in the Link A box and Fuse A for Link A is in the Link B box, There seems to be some parallel wiring in the fusible link boxes that makes it work this way.
    So I inspected the link and it seemed ok. Put a wire across it and the windows and wipers suddenly started working - the first picture above. Then I unscrewed a bolt and the link broke entirely on its own - second picture above.
    Removed it and ended up snapping it into 3 easily. It was way too brittle for a 90A fuse. Since its the fuse for Link B the engine started and ran normally. Decided not to use a wire to short the bolts for the broken fusible link - don't want any more October surprises..
    Two fusible links on order now. Thanks to shogun for pointing the way. Amazing how something I struggled with for nearly a year was solved just like that.
    Alan
    Dec 2004
    CT, USA
    e28, e34, e39
    In pic 1 that fusible link is not installed correctly. It looks like it was already broken on the left and just barely touching on the right.
    demet
    Oct 2018
    Birmingham
    E34 525 1990 5HP18
    It wasn't broken on the left when I removed it, but I'll make sure the replacement is correctly installed. Thank you for highlighting that.
  1. Replies: 4
    Last Post: 01-11-2015, 07:58 PM
  2. Weird electrical problem...fan and windows...91 318i
    By KurtTGS in forum 1983 - 1991 (E30)
    Last Post: 04-15-2008, 02:51 AM
  3. Electrical problem=window problems, and others
    By KLEAR in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-14-2003, 03:08 PM
  4. Weird Electrical Problem (Extra Long)
    By Zippy M3 in forum 1991 - 1999 (E36)
    Last Post: 08-14-2001, 02:37 PM
  5. Weird Electrical Problem (Extra Long)
    By Zippy M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-13-2001, 08:28 PM
