I'm trying to identify two brackets (there's a left and right) that are missing from my green car. Having two cars means you can compare things, and that's usually helpful. However, I'm not sure that I've found the right part numbers for these:
They attach between the frame next to the radiator and the headlight bracket/housing. I think the part numbers may be 63128124690 and 63128124689, but the drawing in RealOEM is less than clear (imagine that). Thanks.
Mike Barrett
94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
96 850Ci, Oxfordgrun over silbergrau hell
FWIW, I believe you found the Brackets - EPC headlight group 63.
Unfortunately, it may require an actual purchase to confirm the correct part.
However, I'm pretty confident those are the correct part numbers
http://www.realoem.com/bmw/enUS/show...diagId=63_0036
16 Bracket left 1 63128124689 $3.48
16 Bracket right 1 63128124690 $3.48
Those are the ones
'91 850i 6sp (mint) (sold)
If any of the attachment points are stripped, you can use a plastic self tapping nut (like the rear fenders) or opt for a bolt and nut setup. Access is limited even with a hinged extension.
What "thumbs up" really means
