Results 1 to 5 of 5
Thread: difference in DME's ?
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    i came across this link here on the forum , which indicates that the x....x352 DME's 1 and 2 should be different ? Can someone explain what it could be ?
    https://www.bimmerforums.com/forum/a...0&d=1322067057
    is it the DME itself ? because when we compare chip mapping , they seem to be exactly the same… or they must have been changed by PO.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The DMEs are identical, so are the chips, and it does not matter what you swap, harnesses, boxes, or chips. If I remember right, the only difference between DME #1 and #2 is that pin 85 is grounded on the #2 box so the diagnostic software or the stomp test can tell the two apart. The xxx156 DMEs were used on early E32/E31 M70 with Bosch M1.2 Motronic systems. Later E32 750 used the same 352 DMEs as the e31 850 with M70 with M1.7 systems.
    See the ETM pinout.
    Sep 2018
    Belgium
    thanks alot shogun for info !
    Nov 2015
    Ger
    E31 850iA 1992
    I have read out my original M70 850i automatic DMEs. The EPROMs are different. (i dont remember how many bytes)
    Ich have a second pair of DME: 750i 09/90-11/91.
    These EPROMs are also differnt. 6 Bytes.
    See the pricture. (there are 12 Bytes different -> file ist doubled/stacked, because the EPROM ist double size to the bin data)
    HEX - DEC
    7F - 127
    80 - 128
    81 - 129
    Car runs also fine with equal EPROMs.
    Sunny Cali,
    6.5 second 69 Camaro
    If they are placed in either slot, They work the same.
  1. difference in DME's?
    By M3vanos in forum 1991 - 1999 (E36)
    Last Post: 12-22-2012, 02:41 PM
  2. difference beetween dme 402&403 e36 1992
    By rideabima in forum 1991 - 1999 (E36)
    Last Post: 10-09-2008, 02:46 AM
  3. 93 325i w/ differently dated DME?
    By ggeiss318i in forum 1991 - 1999 (E36)
    Last Post: 04-24-2008, 09:11 AM
  4. Difference between Burgandy & Silver label DME
    By palomoboy in forum 1991 - 1999 (E36)
    Last Post: 07-01-2006, 07:39 PM
  5. What's the month cutoff for the different DME's for 1995?
    By krisko in forum 1992 - 1999 M3 (E36)
    Last Post: 02-21-2005, 08:32 PM
