Results 1 to 5 of 5
Thread: 1986 325e power steering grinding
    Oct 2018
    roseville ca USA
    1986 325e
    hello,
    So I replaced my power steering belt and went to go drive and immediately got a grinding noise from the power steering. I loosed and tightened the belt but still the same noise. There are several air bubbles in the liquid bottle and sprays everywhere with the cap on. Any help?
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    with no belt on, does it also make noise?
    No e30s again.
    Oct 2018
    roseville ca USA
    1986 325e
    Quote Originally Posted by superj View Post
    No I currently have it off right now and it makes no noise only when I put it on it does
    Dec 2005
    No e30s, again :(
    it sounds like something in the pump is bad
    No e30s again.
    Joliet,IL
    87 325is 96 GMC Suburban
    I had an 86 325es that was doing the same thing. Ended up being loose bolts (one missing completely) holding the p/s pump case halves together. It wasn’t leaking fluid so I’m assuming it was sucking air through that joint and where the bolt was missing. You might look for that and then I would check fluid level of course, while it’s running, and when turned off. Also check the power steering hose for leaks, the hose clamps underneath the reservoir could be loose, or the reservoir could be cracked/split as well.
  1. 1986 325e Power Problem
    By e30IsBae in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-27-2018, 10:57 AM
  2. E46 power steering grinding and vibration
    By rangerfan93 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-19-2013, 03:54 PM
  3. 325e power steering pump
    By liveon2legs36 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-17-2009, 02:57 PM
  4. Replies: 10
    Last Post: 10-09-2007, 01:54 AM
  5. 1986 528e power steering
    By nds19677p in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-16-2007, 09:17 PM
